Muffler fastener bolts
Old Jun 25, 2011 | 05:30 PM
Mr.Softy's Avatar
Mr.Softy
Default Muffler fastener bolts
My Rush slip ons arrived today and I am trying to install them. I have everything loose but the 4 muffler fastener bolts. I don't think I have a wrench that fits them. I tried a 3/8 and a 5/16" wrenches but they don't quite fit. Manual doesn't say what size they are just to remove them and the torque. What size/type wrench will I need for these. Looks like a trip to Sears, I really need a better set of wrenches.
Old Jun 25, 2011 | 05:35 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
1/2" for the flange bolts. Use a socket on an extension with a ratchet. It makes things much easier.
Drew
Old Jun 25, 2011 | 05:45 PM
Mr.Softy's Avatar
Mr.Softy
Drew
I got the clamp bolts loose. The ones I am talking about are on the muffler support bracket and there are 6 of them not 4 like I posted. They hold the muffler to the bracket, and are about 3/8" head size.
Edit... Just took another look at it. There is a muffler support bracket with 2 1/2" nuts on the lower part and the passenger peg bolt on the top. Are they the ones you're talking about?
Last edited by Mr.Softy; Jun 25, 2011 at 06:23 PM. Reason: proper name for bracket
Old Jun 25, 2011 | 05:50 PM
95yj's Avatar
95yj
If 3/8 is too big and 5/16 is too small then you're at 11/32. Not really a common size, but most wrench and socket kits come with it. Unless of course it's an 8mm or 9mm but I doubt it. Only metric crap on most Harleys is battery or brake related.
Old Jun 25, 2011 | 06:26 PM
Kojax's Avatar
Kojax
Angry
the 4 bolts are a pain in the *** to get off. i had harley put my mufflers on my 2010 fatboy lo. it cost 35.oo dollars well worth it .
Old Jun 25, 2011 | 06:40 PM
user 37474839's Avatar
user 37474839
+1 on the FB Lo muffler bolts being a pain to get to.
Old Jun 25, 2011 | 08:21 PM
Mr.Softy's Avatar
Mr.Softy
At this point paying $35.00 seems worth it. I have gone this far though so I would really like to see it through. The job seems so simple until you get to these bolts.
Old Jun 25, 2011 | 08:36 PM
OldCoddger's Avatar
OldCoddger
Just installed mufflers on my '10 FBL and the 6 bolts take a 3/8 wrench. They were a PITA but once I got them started was able to tighten them with a good rachet wrench. It can be done just take a while.
Old Jun 26, 2011 | 10:08 AM
Mr.Softy's Avatar
Mr.Softy
Almost finished now. The bolt heads were 3/8" as you said and they are a PITA. Once I got the bottom muffler off I removed the muffler support bracket and was quickly able to get to the remaining bolts on the top muffler. I put it back the same way. Going back out now to torque everything.
GzrGlide
Oct 30, 2015 12:31 PM
orangehotrod
May 14, 2013 07:47 AM
bigdog1949
Wheels/Tires
Feb 10, 2012 09:55 AM
boner151
Jan 7, 2012 10:03 AM
jterp
May 11, 2007 08:33 PM
