New pipe installation tips and tricks
Old Jun 25, 2011 | 09:48 PM
Reber's Avatar
Reber
6th Gear
Default New pipe installation tips and tricks
This will be my first pipe swap on my 09 Crossbones. Looking at wrapping up some Vance and Hines Big Radius 2 into 2s. Just looking for some tips and tricks that will make this go as smooth as possible! Thanks
Old Jun 26, 2011 | 09:38 AM
TheTroupe's Avatar
TheTroupe
Their site doesn't have much installation help. If it uses stock tapered exhaust gaskets I would recommend a Jims Exhaust gasket tool to make seating them a lot easier.
Old Jun 26, 2011 | 09:48 AM
wiseguy2day's Avatar
wiseguy2day
You want tips on wrapping or installing, or both? Wrapping: start at the outlet and work towards the head. Make sure it's wet when you wrap it so you can get it very tight.
Installing: take your time, when you're done you won't believe how easy it is and how much money you saved by doing it yourself.
Check youtube for both of these, plenty of videos on both.
Old Jun 26, 2011 | 10:01 AM
Fierofly's Avatar
Fierofly
Wrappin, I used Lava wrap, light olive drab color (advertised as a carbon fiber look)I bought off E-Bay $40 50ft., took stock pipes off and wrapped DRY. Stuck a pole in the ground that fit inside the pipe and pulled super tight. Been on for 400miles and has not changed color. Wasn't sure if I'd like the color but it grew on me, might paint flat black in the future. Should be interesting to see how the stock pipes hold up to the heat. I also punched out the cats in the stock mufflers, added alittle more sound. See Photo album for pictures.
Old Jun 26, 2011 | 03:37 PM
m i k e's Avatar
m i k e
wear rubber gloves , use spray bottle to soak while wrapping, get color of sealer to seal wrap when done, enjoy smoke show when your done 1st 1-3 rides LOL
Sadthorn
Exhaust System Topics
Aug 21, 2011 01:00 PM
gambler_m_99
General Topics/Tech Tips
Jun 14, 2010 06:49 PM
Grugrux34
Feb 7, 2010 08:24 AM
jecedr
Oct 19, 2007 05:57 AM
tonygret
Feb 14, 2006 06:18 PM
