Charging Upgrade
I need to upgrade my charging system as i have too much load on it my regulator is toasted. I already tested the stator its not shorted to the ground and its giving out good ac voltage, that i checked with multimeter and test light. and while running over 1000 RPM its only charging about 11.4 barely touching 12 v and i jus put new HD battery aswell. i guess this concludes regulator not working efficiently. By the way i got JL HD600 amp and two alpine type r 6x9 in the hard bags, and passing lamps installed. My fatty is born 2006 and it has 38 amp 3 phase stator. i need to kno can i upgrade my stator to 50 or 60 amp screaming eagle ultra classic stator and regulator or is there any aftermarket charging system available. any input would be really appreciated.
sandhu
I added a second headlight when I put a Road Glide fairing on, added driving lights, amplifier for my GPS tunes,needed power for my video camera and extra lights on the rear tourpak.
Shown about half way down this page shown as "3Phase Charging System"
http://www.compufire.com/harley-main.html
Also some good info here:
http://www.bigdogbiker.com/forums/ho...p-3-phase.html
sandhu
sandhu
Can't say.. had a local shop install it.
