No. The possible issue that could cause damage to the motor would be if you add an a/c without a tuner as the engine mixture will become even leaner than it already is but without changine the a/c you will be fine.
Thanks for the info... I was also looking on different websites for a PCV... I have come across different prices for the PCV... is there a difference in PCV's? For example, Eastern has a PCV for 280, but they also a have a PCV "autotune" for 350...
1. Hows the sound? Not looking for real loud, but definitely want deeper than stock.
2. If only changing the exhaust, will this require any changes to the fuel ratio (other words can I hold off on the fuelpak, Power commander, whatever, until I upgrade the intake (air cleaner/filter)?
Thanks for the help in advanced.
I had one on my Deuce for a while and even though it's bark was not too loud, I thought (and still do) that it's the best sounding pipe on the market.
