Changed the primary oil and...
Old Nov 8, 2006 | 01:19 PM
scrawfordFLSTC's Avatar
scrawfordFLSTC
Default Changed the primary oil and...
...when the bike is cold, the first time or two going up into second gear, it's very stiff, after that it's fine. Also, it took more oil than the manual says to fill it. Does all of this sound normal?? Thanks!
Old Nov 8, 2006 | 02:00 PM
BrianK's Avatar
BrianK
Default RE: Changed the primary oil and...
Could be related phenomena. If you overfilled the primary, I would think that could affect your shifting...
Old Nov 8, 2006 | 02:03 PM
HarleyWood's Avatar
HarleyWood
How much and what kind of oil did you use? I generally just dump in a quart with no problems. I have been using Drag Specialties primary fluid and have been happy with it.
Old Nov 8, 2006 | 02:47 PM
oldgeezer's Avatar
oldgeezer
If the primary is over filled, it might slip a little. I can't imagine it shifting harder. Might check your chain adjustment.
Old Nov 8, 2006 | 03:33 PM
scrawfordFLSTC
ORIGINAL: HarleyWood
I used HD fluid, almost two quarts. I put the bike on the jack and filled to the bottom of the primary cover opening; like the manual says. There's no slipping or any other ill effects, and once the gears have been runs through and everything heats up, everything is fine.
Old Nov 8, 2006 | 04:08 PM
oldgeezer's Avatar
oldgeezer
For my Softail Standard, the manual says to use 26 ounces. It seems to me like two quarts is too much.
Old Nov 8, 2006 | 05:46 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
over filling will make the clutch not want to disengage. 2 quarts does sound like alot
07 Dyna book says 32 onnces
Old Nov 8, 2006 | 06:15 PM
scrawfordFLSTC
I agree that two quarts sounds like a lot, but I thought the manual said fill to the bottom of the primary opening...I'm going to go out and re-read the manual and make sure.
Old Nov 8, 2006 | 06:22 PM
Bighorse's Avatar
Bighorse
Two qts is too much. The Harley oil is ok but give some thought to a few of the synthetics.
Old Nov 8, 2006 | 06:35 PM
scrawfordFLSTC
I realize this isn't rocket science, but the book seems to contradict itself. The Clymer's manual says to put the bike in an upright position (not on the jiffy stand) and fill with the recommended quantity (26 oz.). It also says "The oil level must be even with the bottom of the clutch opening or at the bottom of the clutch diaphragm spring." So, is it 26 oz. or the afore mentioned statement, because 26 oz. doesn't get it to that mark. thanks for everyone's help on this simple but mind-boggling issue...
