Harsh riding Deuce
Old Jul 14, 2011 | 09:58 AM
brihvac's Avatar
brihvac
Default Harsh riding Deuce
My 07 Deuce really rides rough. I cringe when I see a bump in the road because I know its gonna be a huge jolt. I am 250lbs and ride solo. I never realized how bad it was till I took a long ride on the StreetGlide the other day. I do not remeber my 07 Nightrain being like this. It rode pretty good. The Deuce only has 2,500 miles on it. Some ideas I had were to adjust the preload on the rear shocks and change the oil in the front springs. Was also thinking of putting in Progressive front springs but I do not want to lower anything. I like the way the bike sits now. Any ideas on what I can do?
Old Jul 14, 2011 | 10:06 AM
JakesDad1's Avatar
JakesDad1
I had same problem with my new Xbones. Adjusted the preload made a significant difference. Bike from factory is only set for 180 lb load.
Old Jul 14, 2011 | 12:41 PM
bensonjv's Avatar
bensonjv
Preload adjustment is free so second that as your first option. If it's still not what you want, consider Progressive shocks, fork springs, and heavy duty fork oil.
Old Jul 15, 2011 | 08:52 AM
tmitchellof PG's Avatar
tmitchellof PG
I agree that you should firm up your shocks before you decide to replace them. This will keep the bike from bottoming out.
Softail models come from the factory at the softest setting. This is for a 180lb rider.
For reasons that don't make sense to me the factory loctites the shock retention nuts, so you may have to use heat on them the first time they are broke loose. Do not use loctite on them when you are done.
Most Softail owner's never adjust their shocks, regardless of how much weight the bike is carrying. This is mostly because either they don't know how to do it or don't realize that they are adjustable.
I don't know why the dealerships don't spend a few minutes and show new owner's how to adjust the shocks when they are selling the bike.
Tom
rustyj671
Mar 14, 2016 07:45 PM
sparerib
Mar 25, 2013 03:46 PM
twiceretired
Jul 3, 2009 11:35 PM
twiceretired
Oct 13, 2008 10:34 PM
andycg
Apr 15, 2007 12:42 PM
