Headlight troubles
Old Jul 16, 2011 | 01:57 PM
7westwill's Avatar
7westwill
Stage I
Default Headlight troubles
I just replaced my headlight bulb on my 2006 Night train and its not working. The wires that power the bulb have no power
I tested the bulb and its good I also checked the fuses and there all good. Also when i toggle the hi/lo beam switch the hi beam indicator light comes on. Can anyone provide any help? I would really appreciate it. Thanks
Old Aug 2, 2011 | 08:03 AM
vizcarmb's Avatar
vizcarmb
I have the same problem. Anyone wanna help us?
could be a pinched wire if you changed handlebars
Old Aug 2, 2011 | 08:23 PM
BIGGEO's Avatar
BIGGEO
Where did you test? At the connector? Remove bulb and test the wires, my problem was in the connector! Just needed to solder the connector mounting tabs!!! Hope this works! Cheap fix!
Old Aug 2, 2011 | 09:18 PM
oct1949's Avatar
oct1949
There is also a section just for Elc problems in here..
if U dont resolve, might try there.
https://www.hdforums.com/forum/elect...-injection-55/
liamw76
Electrical/Lighting/Alarm
Apr 22, 2017 03:50 PM
langwilliams
EVO
May 13, 2016 08:34 PM
grlflh
EVO
Aug 13, 2012 08:40 AM
Ajackson9687
Jun 15, 2012 07:43 PM
Stevieskull
Nov 17, 2011 02:19 AM
