LED headlamp daytime visability
Old Jul 16, 2011 | 03:23 PM
red deuce's Avatar
red deuce
Default LED headlamp daytime visability
Has anyone else noticed that cagers barely notice you when passing cross streets where they have the stop sign? They about turn right in front of me. It seems ever since I installed the HD LED headlamp this is becoming a problem or since its summer people in my town are driving like idiots, idk.
Old Jul 16, 2011 | 04:21 PM
TheTroupe's Avatar
TheTroupe
Has nothing so do with your LED headlamp, they are just idiots.
Old Jul 16, 2011 | 05:15 PM
PanHeadRich's Avatar
PanHeadRich
You might be right. I definitely notice a difference when I'm using running lamps & headlight during the day. With both Running & Headlamps lighted, get a lot less A-Holes pulling out on me from cross streets & intersections.
I don't personally know much about the LED Headlamps. Are they somewhat directional? Meaning is it significantly brighter from a straight on view vs. offset view from the side? Sorta like HID Projectors? If so, that may be the issue.
Old Jul 16, 2011 | 05:40 PM
red deuce's Avatar
red deuce
Yep, bright straight on and from the sides you see very little light if any. Anyone else noticing this?
Old Jul 16, 2011 | 06:44 PM
jbg's Avatar
jbg
I run mine on the high-beams during the day. Haven't had any issues so far. I love the light and I'm considering adding the LED passing lights when I can as well. WAY WAY WAY more light than the factory bulb.
Old Jul 16, 2011 | 07:58 PM
FXSTaCy's Avatar
FXSTaCy
Glad you posted this. I have 8K HID in the 'Busa and it works great, very distinguishable and bright. Installer said the bucket in the HD was to small for HID install and suggested I look into LED as an option. Appears they don't to get you noticed enough though. Maybe I'll look into larger buckets for HID.
Old Jul 16, 2011 | 11:42 PM
Youngneg's Avatar
Youngneg
wow!!!.....must be bored to death
Old Jul 17, 2011 | 07:07 AM
Redder's Avatar
Redder
yep ...i notice this too. i tilted my led up a little for more visibility. but it is def not as noticable during day unless viewed from straight on.
if you see any new audis or bmws driving around with their xenon projector headlights you kind of see same thing. side visibility is low ...straight on is bright white so, this is not unique to our led lights.
....but, obviously we have much less surface area/size
Old Jul 17, 2011 | 08:18 AM
Jedx66's Avatar
Jedx66
I have the LED's and haven't had an issue. While it's possible the LED's may be directional I personally find the beam at night to be very wide and bright. Now, I always run the Hwy lights and maybe this is the difference??
Old Jul 17, 2011 | 11:09 AM
Tom84FXST's Avatar
Tom84FXST
To me all LEDs are not as bright in direct sunlight as regular bulbs...even though the are brighter in shade or dark conditions...go figure.
