New filter replacement and new pipes
Old Jul 18, 2011 | 01:58 PM
Lutzinator's Avatar
Lutzinator
5th Gear
Question New filter replacement and new pipes
I have a 2010 HD Fat Boy Lo and I just installed American Custom exhaust slip-ons and replaced my stock filter far a K&N filter. The filter is just an Orm replacement and fits the standard HD air cleaner football. My question is, do I need to install a computer or get the engine carbs rejetted or can I leave the bike as is with what I installed and ride with no problems?
-Thanks
Old Jul 18, 2011 | 02:22 PM
jeffreydsilver's Avatar
jeffreydsilver
Default How Does It Run Now?
The big question is, how does it run now as compared to before the changes. When I swapped out my stock mufflers for AC slipons, the bike (09 Road King) had a new noticeable "pop" almost like the beginnings of a backfire during decel. I didn't notice any change in MPG. This led me to believe it was running a bit to lean. I bought a V&H Fuelpak, got in touch with the V&H factory (really good customer service) and they suggested a map for just changing the pipes, without the air filter.
Long story short, the bike runs great. No more decel pop and a slight reduction in MPG (running richer now). If the bike runs correctly, I'd leave it alone, if not I'd explore options.
jbg's Avatar
jbg
Well first of all...you don't have a carb on that bike. So no need to rejet anything. The only thing left for you to do is add some fuel management. By adding the new K&N, you added more air to the mixture. So now your bike is running even leaner than it did from the factory. The computer will compensate for a little of that, but you should seriously consider adding some sort of fuel management to add some fuel back into the mix and cool down the bike a little. It'll also give you some more power. You can do the V&H FuelPak or a PC. If you're not doing any further engine mods, the FuelPak will do what you need. It's what I use on my bikes. Good luck and nice choice of bikes!
Old Jul 18, 2011 | 06:37 PM
oct1949's Avatar
oct1949
read through this and U should learn something..
http://www.nightrider.com/biketech/m...i_upgrades.htm
Old Jul 18, 2011 | 07:30 PM
Lutzinator's Avatar
Lutzinator
5th Gear
Well thanks for the info, so basically I need to remap and get a fuelpak. Another question that I have is if I left the stock HD filter in and ran the AC slip-ons would I also need to get the fuelpak? I have heard and read if you change either the exhaust or the filter you don't need to do anything, if you change both the exhaust and the filter you need to remap, rejett, or change something?
Old Jul 18, 2011 | 08:07 PM
jbg's Avatar
jbg
You don't need to remap if you get the fuelpak. You need one or the other. You also don't need the fuelpak if you just do the pipes. More air = need for more fuel.
Old Jul 18, 2011 | 08:47 PM
TheTroupe's Avatar
TheTroupe
Did you get one of these first?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
A Stage 1 air cleaner upgrade is more than a filter swap.
And yes with a Stage 1 filter change you should remap the ECU for better performance.
A modern system, with O2 sensors will compensate for the added air but it will not auto tune for peak performance.
Old Jul 18, 2011 | 08:51 PM
Lutzinator's Avatar
Lutzinator
5th Gear
Thanks for all the info! And no I just bought a replacement K&N air filter that fits my stock air box. I will have to decide on keeping the original air filter or buying the fuelpak.
-thanks
BEN-Z
Aug 19, 2014 07:00 PM
fyrmnk
Exhaust System Topics
May 19, 2012 08:39 AM
rufio80
Mar 14, 2012 03:36 PM
ault27fxdc
Feb 22, 2011 07:21 PM
chromedome
May 24, 2008 10:12 PM
