no spark after wash???? need help quick
Old Jul 30, 2011 | 04:19 PM
Keith_71's Avatar
Keith_71
Default no spark after wash???? need help quick
just as the title states i have a 02 softail standard carb. washed the bike last nite and today it wont fire, everything works just no fire to the plugs??
Old Jul 30, 2011 | 04:31 PM
gbody805's Avatar
gbody805
Might be wet plug wires. Worn and cracked wires will hold water and direct the spark to ground.
Might hurt alittle but hold the wires loosely in your hand and crank the bike, if you get a little goose then bad wires are your problem.
If not then something else is wet and needs to be dried. Might be a electrical plug.
Old Jul 30, 2011 | 04:43 PM
jermflux's Avatar
jermflux
Have you pulled the plug wire and used a screwdriver or something see if you get an arch to the engine?
Old Jul 30, 2011 | 04:50 PM
Keith_71's Avatar
Keith_71
yeap nothing going to the plugs
Old Jul 30, 2011 | 04:58 PM
Keith_71's Avatar
Keith_71
checked all the fuses too
Old Jul 30, 2011 | 05:35 PM
jermflux's Avatar
jermflux
Grab a multimeter and check for voltage to your coils. Check the terminals for the electrical connections on the coil pack too. A little corrosion there may be causing the problem.
Ndoggct
Sep 21, 2016 07:02 PM
scorchedearthpolicy
Jul 6, 2010 08:34 PM
zaxcar
EVO
Oct 18, 2009 03:44 PM
dgretz
Sep 15, 2009 08:36 PM
paintballoma
Jun 6, 2007 11:18 AM
