2 questions...2000 softail
Old Jul 31, 2011 | 08:45 PM
fatboy1017's Avatar
fatboy1017
Default 2 questions...2000 softail
The most important one is.....behind where my rear cylinder bolts to the block on my FLSTF, the case comes together, there is a elongated oval. What is it, and why is it leaking oil?
Question #2........My dealer suggested a 150 rear tire, I went with it. I just noticed it is rubbing on the left side. Should they have shimmed it or something?
Old Jul 31, 2011 | 11:35 PM
kkiley's Avatar
kkiley
Seeping between the cases is not uncommon. More of a nuisance than a riding issue. The fix is not cheap and requires splitting the cases.
What is the rear tire rubbing on? Could be corrected with an adjustment of alignment...
Old Aug 1, 2011 | 08:24 AM
hspring03's Avatar
hspring03
A 150 is a little big for a 2000. It can work though. Did the dealer reverse the fender bolts and put acorns on the outside?
Old Aug 1, 2011 | 09:45 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Certain brands of 150's I put on my 02 rubbed on the belt guard. I took the belt guards off. Determine what it is rubbing on and proceed from there.
Drew
Old Aug 1, 2011 | 07:06 PM
fatboy1017's Avatar
fatboy1017
They did not reverse the bolts, I stopped by the dealer after work today, and the re-aligned it. I did hit a MONSTER pothole a few days ago. And the cases would need split to fix my small leak. Thanks for your answers guys.
Easy 13
Wheels/Tires
Jan 1, 2016 08:31 PM
Wabbit
May 10, 2014 11:19 AM
Krupp172
Wheels/Tires
13
Aug 23, 2012 09:47 AM
sgt.lopez
Nov 6, 2008 12:09 PM
jd_underdog
Jul 15, 2006 09:38 PM
