New Speedo/Tach Combo
Old Aug 2, 2011 | 08:32 AM
cmosentine's Avatar
cmosentine
Default New Speedo/Tach Combo
Anyone install the new Speedo/Tach combo (gauge within a gauge) on a 2008-2010 FLSTF? Was the install smooth? How's it working for you?
Old Aug 2, 2011 | 05:13 PM
Mathis's Avatar
Mathis
I put this one in my 2010 Heritage. Very easy install and it works great.
Old Aug 2, 2011 | 05:46 PM
TNB's Avatar
TNB
I know several of us went with the other speedo/tach combo on Fatboy Lo's.
Old Aug 2, 2011 | 05:48 PM
Sgt_Jim's Avatar
Sgt_Jim
i have the same one Mathis installed on my 2010 FatBoy Lo..install was very very simple and straightforward.. and didn't even need to plug the device in to the ECM to get the mileage, was updated automatically.
Old Aug 2, 2011 | 05:51 PM
HarleyCamper's Avatar
HarleyCamper
Put mine on a Deluxe and am very happy with it.
Attached Thumbnails New Speedo/Tach Combo-dscf6293.jpg
Old Aug 3, 2011 | 12:50 PM
ejohnson1's Avatar
ejohnson1
Pardon my ignorance but...
I am assuming you replaced a regular speedo with this. Did you have to do anything special to get the tach & fuel gage working if there was none there before, or is all the info already being send through the existing wiring?
Am I correct that the odometer reading is in the ECM now and so they do not require dealer certification anymore?
This model has the switchable colors and uses the odometer toggle button to select them, right? How does that work, obviously you don't want to go through the colors everytime you switch your odometer readout.
Thank!!
Old Aug 3, 2011 | 01:22 PM
cmosentine's Avatar
cmosentine
I chatted with the head mechanic at Sandy's HD about this. We even opened a package to look at the instructions.
Before the unit can be used you must transfer the odo data from the ECM via the provided pigtail that plugs into the service port under your seat.
As far as the tach, no special wiring was needed, so I guess it must get this info from the ECM. Fuel would also come from the ECM as that data must be present on existing speedos to calculate range.
Lastly, from the HD web site, the gear selection is simplify calculated from the speed/rpm relationship. This of course will assume stock gearing.
Old Aug 3, 2011 | 02:07 PM
Sgt_Jim's Avatar
Sgt_Jim
I didn't have to do that, just plugged it in and everything was fine on a 2010 FLSTFB.. maybe the 2011's and up, but not the 2010's and down
Old Aug 3, 2011 | 03:02 PM
cmosentine's Avatar
cmosentine
Cool. One less step.
Old Aug 3, 2011 | 03:31 PM
HarleyCamper
Perhaps this picture will help you.
