extra drain plug
Old Aug 3, 2011 | 02:42 PM
Softail HA's Avatar
Softail HA
Default extra drain plug
Just finished changing the Transmission fluid in my 11 heritage,what is the small little drainplug underneath the bike that is close to your floorboard on the right hand side. It is not the primrary drainplug,or the engine oil drainplug.Thanks
Old Aug 3, 2011 | 03:04 PM
DC Mike's Avatar
DC Mike
That is the engine case drain plug. But DO NOT pull it for draining purposes!! Not only is it not necessary to use it for changing the oil, it is VERY easy to strip that hole. If you do a quick search there are a few members that have been UN-lucky enough to have to deal with this problem. Just pretend that it doesn't even exist and you'll lead a happy life! Hahahaha
Mike
Old Aug 3, 2011 | 03:29 PM
Softail HA's Avatar
Softail HA
Whoops to late, I carefully put it back in .Should I just top up my oil, or like usual is it going to be more difficult than that . Thanks.
Old Aug 3, 2011 | 04:21 PM
luvtoride's Avatar
luvtoride
you probably only got 8-10 ounces of oil out of that hole..just hope it doesn't leak now. You're not the first and you won't be the last....R T F M!!!
Old Aug 3, 2011 | 07:18 PM
Softail HA's Avatar
Softail HA
Lol-- point taken.
Old Aug 3, 2011 | 08:05 PM
XARAN's Avatar
XARAN
Be careful tightening that sump plug, it is a taper thread and too tight will crack the cases
thedonthere
Mar 26, 2019 09:47 PM
PhatBoyHigh
Nov 25, 2015 11:11 AM
barrywilson
Oil Archive (no new posts)
Nov 23, 2014 03:58 PM
thunderchild223
May 30, 2011 09:31 PM
Tonefiend
Sep 26, 2010 09:04 AM
