Oil Temperature
Old Aug 21, 2011 | 06:29 PM
arealinvestor's Avatar
arealinvestor
Originally Posted by Black Beauty
I am new to Harley riding, and bought a 2011 Fat Boy Lo. I have installed a screaming eagle air breather and V&H big radius 2-2 pipes. The dealership put in their recommended EFI map.
When riding around the city, my legs get extremely hot from the engine, to the point where it is quite uncomfortable. I put in an oil tank temperature gauge, and when riding in low humidity, at 22 Deg C (72 Deg F), the oil temperature gets to about 120 Deg C (248 to 250 Deg F).
I hit a fair amount of red lights, but normal city driving with light traffic.
Can anyone advise if this is a normal oil temperature, or is my bike running hot? If it is running hot, does anyone have any idea of what might be the cause?
I have about 2000 KM on the bike, and switched to AMSOIL 20W-50 synthetic after the break in.
Any help would be greatly appreciated.
You need a good tune,not a downloaded map.Go get a dyno tune!! your bike is probably lean!!!
Old Aug 21, 2011 | 08:37 PM
Royal271's Avatar
Royal271
I've got to get a oil temp gage....
Old Aug 21, 2011 | 09:07 PM
TUCCI's Avatar
TUCCI
Dont get obsessed with constantly looking at the oil temperatures. It's an air cooled engine and they are going to run hot. Usual oil temp from my research is 240-280 which is within the normal operating temperature of most newer stock motorcycles. It won't damage or hurt the engine and any good synthetic oil can handle those temperatures with no problems. If you buy a guage your going to be looking at the dang thing all the time and get obsessed with it mark my word. Research all the threads on oil coolers and pick one. Then ride it and enjoy it. If your not using a synthetic oil research the threads and pick one also....Tucci
Old Aug 21, 2011 | 09:33 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Assume you are using a dip stick gage. Put it in water and soon as it boils note the temperature. Should be 100C/ 212F . Bet you gage is reading high. Hard to believe you are running that temperature at 22C/ 72F . I run around 105C/220F at 95 degree. Don't forget to allow for elevation up there in you calibration if necessary. What's your boiling temperature?
Old Aug 21, 2011 | 10:28 PM
baust55's Avatar
baust55
I bought the Capt'n Itch Crotch Cooler . Works good ,looks great ! I got the basket weave embossed one to match my stock roadking seat and bags,
Old Aug 21, 2011 | 10:49 PM
Bluehighways's Avatar
Bluehighways
Originally Posted by billfitt
I have a 2010 heritage and had the same exp as you all. The first weekend I got stuck in traffic and could barley stand sitting on the bike. I installed a hd oil cooler and the temp is around 220. It's still hot but more tolerable.
Same experience and same results from using the HD Oil Cooler.
Old Aug 27, 2011 | 01:59 AM
dfndr's Avatar
dfndr
Try XIED. For a hundred bucks or so it seems to give richer and cooler fuel mixture. Everyone on this site seems happy with lt. Good luck.
Old Aug 27, 2011 | 06:56 AM
HighwayStar503's Avatar
HighwayStar503
I think your oil temp is normal, 250 is not too high at all
Correct me if I'm wrong but the ECM doesn't shut down the rear cyclinder til it reaches the 290-300 degree range
My Lo has a well tuned, high compression 107" putting out 120+ HP and it runs in the 230-250 degree range. Even if riding hard on the hottest of days, it never breaks the 250 mark
Old Aug 27, 2011 | 07:53 AM
Jester750's Avatar
Jester750
For the heat discomfort on my legs I went with the RJ's originals heat shields. I got the plain black and they match my denim black Fat Boy Lo so well, people barely notice that I even have them on. I am very pleased with how they work and how they look on the bike. I think if you search the vendor part of the forum there is a code for a discount for forum members.
Here is the site:
http://www.rjsoriginals.bizland.com/newSelect0010.htm
Old Aug 27, 2011 | 08:32 AM
LocoPilot750's Avatar
LocoPilot750
I put the Xied's on my '07 last month, and it did bring the head temps down quite a bit. It feels more like what I'd consider "normal" now, instead of scorching hot. And my Harley oil temp guage is showing about 8 deg hotter than it should, so I factor that in when I look at it. I tested it against a high quality candy thermometer from Mama's kitchen, in boiling water.
