Buddy's softtail bottoms?
Old Nov 13, 2006 | 10:56 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: Buddy's softtail bottoms?
ORIGINAL: ZJAvy
Take pics of it, a lot and post them on photobucket (its free) then post the link to the pics here so we can take a looksy please. Measure from the bottom of the frame below the swing arm pivot bolt and tell us that measurement so we can figure out whats up.
Good idea, also see if you can take a pic or two with it standing straight up with him on, and off it. Post those along with the measurements. My guess is that somethings not quite right with at least one of the spring shocks.
I know this is going to sound dumb, but look underneath and make sure that they are bolted in properly.
Old Nov 14, 2006 | 05:11 AM
softail2005's Avatar
softail2005
The Deluxe is the lowest of the softtails when it comes to ground clearence, with 4.8 inches off the ground. My wife and I ride double most of the time and I weigh 205 and she weighs 125 so thats a good load to haul. I jacked the shocks up a bit and it made a world of difference.
The shocks may have come from the factory without any preload adjustment and simply need to be cranked out a bit. I agree with the advice to see your dealer for a shock check.
You will drag any softtail footboard if you over correct in the corners. Watch your friends track into and out of the corners and make sure he making a smooth curve through the corners and not doing a 90 degree turn and doing the overcorrection.
Old Nov 14, 2006 | 10:50 AM
ZJAvy's Avatar
ZJAvy
I just cant see a beginning rider leaning the bike over enough to drag the floorboards without incident. Im leaning to somethings not correct on the bike is most likely an easy fix. If you take it back to the dealer and they go um oh OOPS, its fixed now. Tell em good now replace my floorboards because they are damaged due to your (the dealers) error.
Old Nov 15, 2006 | 04:55 PM
ORCUTTHD's Avatar
ORCUTTHD
Thanks for all the info.
Found out it is not the floorboard hitting, it is the kickstand.
Going back to dealer and getting it raised a little.
Old Nov 15, 2006 | 05:31 PM
RandyM1911's Avatar
RandyM1911
Kickstand? That's a new one. Is the spring not holding it up all the way and it's hanging down?
Old Nov 15, 2006 | 05:37 PM
ZJAvy's Avatar
ZJAvy
please explain, my interest is peaked!
Old Nov 15, 2006 | 06:01 PM
ORIGINAL: ZJAvy
Me too. This sounds interesting, and a little odd.
Old Nov 15, 2006 | 06:11 PM
Hardley riding's Avatar
Hardley riding
What a weird deal, want to respond to keep it on top, looking for the answer.
Old Nov 16, 2006 | 12:18 AM
ORCUTTHD's Avatar
ORCUTTHD
Update,
No the kickstand is not hanging down, it is tight against the rubber bumper. This thing comes within 1/2" of the ground on a simple parking lot left turn.
Old Nov 16, 2006 | 12:20 AM
ORCUTTHD's Avatar
ORCUTTHD
Deleted
