Fatboy Tire Pressure
Old Sep 1, 2011 | 12:39 PM
INTHERED's Avatar
INTHERED
Default Fatboy Tire Pressure
I just bought a 2011 Fatboy and right now I have my tire pressure set per the owners manual. Should I run a different tire pressure cruising the highway as compared to running twisty back roads ?
Thanks >>>> Inthered
Old Sep 1, 2011 | 12:45 PM
jbg's Avatar
jbg
You should really only need to adjust it for 2up riding. Otherwise...you should be fine following the manual.
Old Sep 1, 2011 | 02:01 PM
skulltrainharley's Avatar
skulltrainharley
Believe me on this one your tyre dont know or care what surface it's on it's 36 front 36 rear and if ya got a pillion it's 42 ....
Old Sep 1, 2011 | 02:04 PM
mikedanben's Avatar
mikedanben
It's printed on a sticker on the Lower front right frame.
Old Sep 1, 2011 | 04:01 PM
Harley_Dude's Avatar
Harley_Dude
Go by what is printed on the tire, some Metzelers run at 50.
Old Sep 1, 2011 | 04:35 PM
cmosentine's Avatar
cmosentine
This is normally the maximum load pressure. Normal operating pressure is usually less.
Old Sep 1, 2011 | 04:37 PM
jreichart's Avatar
jreichart
+1, sort of. Go by what the tire manufacturer recommends. If it has stock tires, the manuals PSI is fine, aftermarket tires, check with the manufacturer. Generally, the PSI printed on the sidewall is a MAX PSI under MAX LOAD conditions, not necessarily an everyday riding PSI.
Old Sep 1, 2011 | 09:59 PM
INTHERED's Avatar
INTHERED
I think I will stick with the owners manual pressures
Windseeker
Oct 6, 2017 09:27 PM
Chunker
Dec 23, 2013 08:42 AM
INTHERED
Aug 31, 2011 06:05 PM
07bobber
Sep 19, 2008 12:45 PM
Legendary6301
Jul 1, 2006 01:46 AM
