Ok at least this ones about the front not the rear
I'm just getting ready to pull the trigger on a new front wheel & tyre a 3.25x21, it will be wearing a 120 70 21 metz
My questions are 1. will I now need to center the front wheel?
2. will i have clearance issues with the stock front end?
3. will i still have room to fit a fender?
4. will this in turn cause issues with brake location?
I'm hoping its just a bolt in job,
many thanks
Dan
If the wheel hub is the same specs as the stock wheel hub I don't see why you would need to re-center or have any brake location issues.
You will definitely have issues with the fender. I slotted the holes on the stock fender to raise it enough to clear the tire. I've sense decided to dump the front fender entirely.
I don't have any clearance issues with my stock front end and my 21" wheel/tire. (Mine is not as wide as what you're going with so I'm not sure if your question was in regards to width clearance or hight.
Heartland makes a nice front fender for a 211" wheel on the rocker. You should be fine with clearance with a different fender and as long as the wheel is built to spec for a rocker it shoudl bolt right on with the same spacers. http://heartlandbiker.com/_product_6...om_21inch_Tire
I think the biggest problem might be the brake clearance. I'm curious about this also, cause I want either a 21 or 23x 3.5 wheel. I know with my 110metz I can't fit the stock fender. I think Heartland and Bitchen' Seats got Rocker fenders for wider wheels.
Drew
thats the one I have for the 21x2.15 im currently running
if it comes to suit a 3.25 x 21 pm me with a price please
Im running the skinny front now too & had no issues, just looks a bit snug for a 120 tyre.
hey jo ( sounds like a hendrix song)
anyway do you think your front fender would fit if you
reamed out holes ?? or no way
yep, the brake clearance & hoping there is enough room to squeeze a fender in.
Bitchin havent replied to my emails... they mustnt want my $$$
