01 FLSTC Wiring ?
Old Sep 19, 2011 | 03:13 PM
B3KHClassic's Avatar
B3KHClassic
3rd Gear
Default 01 FLSTC Wiring ?
Under the seat behind the fuse box I have a loose black box with wires running to it from the rear tail light connector and another set of wires.
This box is being crushed by the seat and I'm just wondering where it should go. I have the HD Manual and none of the pictures show that anything should be in the area behind the fuse box. Just bought the bike and was checking things out when I found this.
Old Sep 19, 2011 | 03:36 PM
hspring03's Avatar
hspring03
It sounds like a RunTurnBrake module.. Makes the directionals running and brake lights.
It goes where ever it will fit. It's an aftermarket part.
Old Sep 19, 2011 | 03:43 PM
B3KHClassic
3rd Gear
Thanks for the help
Old Sep 19, 2011 | 03:50 PM
B3KHClassic
3rd Gear
did a search for the RunTurnBrake module and sure enough after looking at the picture that is what it is
Old Sep 20, 2011 | 03:37 AM
oct1949's Avatar
oct1949
I also have one, not much room for anything extra in there is there.!!
Old Sep 20, 2011 | 08:42 AM
shineybike's Avatar
shineybike
I have mine sitting at the end of the fuse box on the right side. Used a zip tie to hold it in place.
Old Sep 20, 2011 | 09:59 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You can put it right where the wiring comes through the fender and that way it takes up no space. Never had an issue with mine under the seat, however I do not have a stock seat either.
Drew
Old Sep 20, 2011 | 05:27 PM
B3KHClassic
3rd Gear
I was able to stuff my next to the fuse box behind the battery.
http://s1183.photobucket.com/albums/...sunderseat.jpg
Old Sep 20, 2011 | 05:31 PM
B3KHClassic
3rd Gear
I have a saddleman seat and have to be careful as to where it is laying. I had it behind the fuse box and it got smashed up a little, the reason for the tape around it in the previous picture
ncudmore
EVO
Apr 16, 2017 09:45 PM
Casper
Oct 2, 2014 06:20 PM
PJGoose69
Oct 1, 2013 01:19 PM
HOMBRE2011
Apr 25, 2012 12:31 PM
ajpum65
Apr 8, 2008 08:56 PM
