Duece ignition module ?
Old Nov 22, 2006 | 10:47 PM
T1200's Avatar
T1200
Stage I
Default Duece ignition module ?
Bought a screamin eagle ignition module at e-bay part 31763-04 fits softail fxst - FLT. The duece has a twin cam engine like other softail harleys, when I try to start the motor it just backfires, that brain of mine can't figure out why the motor won't run. Is the preset timing of the different module models the problem ? Does anyone know the module part number for duece? Thanks Tom.
Old Nov 23, 2006 | 09:40 PM
Reino's Avatar
Reino
Default RE: Duece ignition module ?
Welcome to the forum Tom.
looking in the parts book the 31763-04 fits all '04 & later Softail models. I haven't got my scanner working right now so I'll type what the book says:-
This module is 50-state street legal, and is programmed to allow the engine to turn 6200rpm. Designed for use on engines with stock compression ratio. E.O. pending on '05 models. (not sure what the E.O. pending means? May have something to do with the EPA as it's written on some of the other Screaming Eagle parts).
Part # 31781-00 fits '00-'03 carbureted Softail models.
rkduq20
Aug 22, 2018 08:21 AM
TangoDown
Dec 2, 2012 10:29 AM
Bluehighways
Sep 6, 2012 06:23 PM
wh1tetrash
May 10, 2008 03:30 PM
hawkyou
Nov 27, 2007 06:30 PM
