HELP... Oil Change question
Old Oct 8, 2011 | 08:51 PM
Ballsout's Avatar
Ballsout
Im using a jack... not a jiffy stand. Not even sure what a jiffy stand is. The bike is back on the ground now... if I level it with some blocks of wood under the kickstand, the oil level is just about 1/4 the way up the stick between fill and full. Its cold. Maybe Ill fire it up in the morning and let it get hot, then check again.
Old Oct 8, 2011 | 08:54 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Check the oil with the bike on the KICK STAND (jiffy stand) for a proper reading. No blocks of wood.
Drew
Old Oct 8, 2011 | 08:57 PM
Ballsout's Avatar
Ballsout
wait a tic... are we talking about a KICKSTAND when we stay JIFFY STAND?
I just googled it and look what ive learned? So the bike is supposed to be leaning to the left on the kickstand, then the level should be checked?
Old Oct 8, 2011 | 08:58 PM
Ballsout's Avatar
Ballsout
Drew
Thanks Doc
Old Oct 9, 2011 | 05:26 AM
FroggyFatBoy's Avatar
FroggyFatBoy
if all else fails, read the owners manual..
Old Oct 9, 2011 | 06:02 AM
fdb2007's Avatar
fdb2007
I use 2 qts + 22-24 oz. Check while hot, but that amount will get you pretty close to the top of the range on your dipstick.
Old Oct 9, 2011 | 09:57 AM
Willie D's Avatar
Willie D
Cool oil change
Don't believe everything you read. . . . 3 qts. +/-
Jiffy stand, check after 2 qts. - then add as required.
Old Oct 9, 2011 | 10:17 AM
skiindean's Avatar
skiindean
About to take my Fat Boy in for my 5k service, I check the oil (hot and on side stand), and I'm 2 QUARTS LOW, it didn't even register on the dipstick after I put the first quart in. I use HD syn3, never noticed any problem with engine, runs great. The oil light flickered on for 2 seconds, which is why I checked it. and yes, I know "check your oil" check your oil", lesson learned. So my bike was running on 1 1/2 quarts, less than half...how much damage did I do, or am I lucky that all runs fine and I caught it. Had it in for my 1K, a dyno tune, had battery replaced at 4k....I guess dealers don't check oil unless you pay them too. 96 engine....I was reading that the 96 can run on 1 quart with whatever the Harley engine has in it to help fail safe. And why wouldn't my dummy light have come on earlier that 2 quarts low? Very frustrated that I may have damaged something, and it is my fault.
Old Oct 9, 2011 | 10:27 AM
Softy 103's Avatar
Softy 103
I doubt if you hurt any thing as long as you didn't run the engine with the oil light on, a flicker of the oil light was just showing you something wasn't right.That is what the oil light is for , as long as you shut it down I wouldn't lose much sleep over it, I would watch it though as the oil had to go somewhere.
Old Oct 9, 2011 | 03:43 PM
murd's Avatar
murd
The "Jiffystand" is one of the funniest words I've ever come across.
Love it.
