HELP... Oil Change question
Old Oct 11, 2011 | 09:42 AM
softailman1227's Avatar
softailman1227
Yeah every time that I've changed my oil it only takes between 2.5 and 3 qts.
Old Oct 11, 2011 | 10:55 AM
Loco-Nut's Avatar
Loco-Nut
What would one need to scavange the oil? I like mine looking clean after changing.
Old Oct 11, 2011 | 11:14 AM
skjskmata's Avatar
skjskmata
Originally Posted by Ballsout
So I dropped the old oil from the drain plug near the rear-rt part of the frame. Changed the filter, and Im adding the oil. Problem is, its only taking about 3qts of oil, and that is showing over full on the dip stick.
Shouldnt it be taking 3.5 qts with no problem? I started to bike to get oil into the filter already, and it is sitting level on a bike stand.
Its an 09 Fatboy. Any thoughts?
I just changed the oil and filter on my '07 Fat Boy (96 ci) a few days ago (just drained the oil and changed the filter, no scavenger). It took slightly less than 3 quarts to refill. As others have mentioned, check the oil level with the engine hot while the bike is on the kick (jiffy) stand. The owner's manual for the '07 says to get the engine hot by riding the bike, not by letting it idle. I have read that elsewhere also, and so that's what I do before changing the oil and before making the final level check after the change.
By the way, when I drain the oil while the bike is on the jiffy stand, I let it drain until it stops dripping, and then I straighten the bike which allows a bit more to drain out.
Old Oct 11, 2011 | 12:09 PM
Radimus's Avatar
Radimus
if you want to clean out the oil system out and don't mind wasting a filter and a quart or 3 of oil (do it once a year, especially you northern boys that garage your bike for the winter)...
Change the oil as you would normally, but use about of 1/3 bottle of Seafoam first, then top off with oil. Ride around for an hour or 3 and then change the oil AND filter again, this time without using Seafoam. Seafoam says you can leave it in, ie, you don't HAVE the change the oil the 2nd time, but I like to use this proceedure as a cleaning of the system and then run fresh after it breaks up any residue and lets the filter catch it.
Old Oct 11, 2011 | 12:30 PM
oct1949's Avatar
oct1949
warm up motor, sit a little to cool pipes, drain oil, Clean and replace plug to correct TQ. Remove filter, (i pour 5 ozs or so in filter and let soak in) replace new filter.
pout about 2 1/2 qts of oil in tank. check and fill to middle of dip stick.
clean up mess....
Old Oct 11, 2011 | 12:57 PM
Fierofly's Avatar
Fierofly
Oil light works off a pressure switch, no or very low pressure and light comes on. Doesn't matter how much oil you have as long as proper pressure is going to the bearings lite stays off.
Bluraven
Sep 12, 2021 04:18 PM
Highgrade
Mar 12, 2016 09:53 AM
truthfire
Apr 4, 2011 02:04 PM
casadelray
May 13, 2010 06:18 PM
ronster2
Oil Archive (no new posts)
Sep 24, 2009 09:46 AM
