Kickstand down switch
Old Nov 20, 2011 | 08:51 AM
  #31
RoadKingHellas's Avatar
RoadKingHellas
and the thing is that I can now operate the bike - I went for a half an hour ride with no issues but the error message and engine light is there.
I have only connected the ground cable with the one from the sensor without connecting anywhere the red/white which is powered by the ECM .
Even if you dont connect these cable still you can operate the bike but getting the sidestand error...
Old Nov 20, 2011 | 09:04 AM
  #32
jeffreydsilver's Avatar
jeffreydsilver
Default Kickstand Switch?
Originally Posted by Pufferman
All years. You'll hear the audible scrape alarm when you make your first left turn. LOL
09 Road King here. NO SWITCH on my bike.
to the "audible scrape alarm"
Old Nov 20, 2011 | 05:16 PM
  #33
Rakthi's Avatar
Rakthi
Nice to hear you sorted it out! Enjoy, and you can clear the error when you get the new switch. Thanks for posting how to connect. Might be usefull for someone on future.
Old Nov 21, 2011 | 03:42 AM
  #34
RoadKingHellas
the question is if I can avoid buying the switch (not have a switch at all) by finding a way to clear the error and engine light ...
any more ideas ? - something you need to do with the red/white cable which connects/powered by the ECM ?
Old Nov 21, 2011 | 04:15 AM
  #35
Rakthi's Avatar
Rakthi
My guess is you would have to solder in a resistor (what value?) to dupe the ECM in thinking the sidestand is up ... I don't think it is a simple on/off thing. Specially since it is also connected to other sensors in the same loop ...
Don't know, wonder how the plug is capped on the US domestic models. I'm sure the harness is the same up to the plug where you plug in the switch. Or else the dealer should be able to turn it off with his "Digital Technician"
Old Nov 24, 2011 | 07:51 AM
  #36
RoadKingHellas
Hi all,
short update :
The good news is that the new switch arrived yesterday , the bad news is that I did not kept a wirring digram thus I dont know which cable to connect. Iam saying this because I removed the plastic connectors so I need to connect the cables directly.
So Red/white from ECM side connects to which color ? wire from Jiffy stand sensor
Green/Brown connects to which color ? wire from Jiffy stand sensor
Black/Green connects to which color ? wire from Jiffy stand sensor
Old Nov 24, 2011 | 08:18 AM
  #37
Rakthi's Avatar
Rakthi
Red/White connects to Red
Green/Brown connects to White
Black/Green connects to Black
Hope you sort it all out, and make sure those connections you make are water proof!
Old Nov 24, 2011 | 08:47 AM
  #38
RoadKingHellas
man thanks !
I let you know how it went
Old Nov 24, 2011 | 12:21 PM
  #39
HDUK's Avatar
HDUK
My kickstand switch got water inside the connection box whilst out on a ride bad design where the connector is in front of the engine and kept cutting the engine out all the way home throwing up error codes so cleaned it with wd40 and covered it with insulation tape cleared the codes and not had any problems with it since
And if you do try put it in gear with the stand down the engine will cut out and can be a bitch to start afterwards
Old Nov 28, 2011 | 02:42 PM
  #40
RoadKingHellas
Rakthi,
Everything went fine, new switch operates normal again - Thanks once more for your valuable input
John
