Slight wobble around 40mph
Old Nov 27, 2006 | 05:40 PM
Jezcruzen's Avatar
Jezcruzen
Default Slight wobble around 40mph
Ever since I replaced the front tire I've noticed a very slight wobble in the steering between 35 and 40mph. I don't consider it to be dangerous, just bothersome. I don't think there should be ANY wobble...period.
I returned it to the dealership thinking it might be a balance issue. They never re-balanced the wheel/tire, but did tighten the steering head, which seemed to dampen the wobble a little. I don't always notice it, but occassionly when traveling at that certain speed I feel it.
This is on a Deuce, BTW, with a stock 21" OEM laced wheel. Any ideas?
Old Nov 27, 2006 | 05:57 PM
sleepneagle's Avatar
sleepneagle
Default RE: Slight wobble around 40mph
check your spokes. each should have that pling sound.
Old Nov 27, 2006 | 05:59 PM
Denbo's Avatar
Denbo
I would of figured it to be out of balance,could some of the spokes be loose and causing that problem.
AK_Hog_Herder's Avatar
AK_Hog_Herder
And check the obvious.
Is the tire rotating in the correct direction? Look at the big azz arrow on the tire.
Old Nov 27, 2006 | 06:02 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Other than the spokes that sleepneagle mentioned I would insist that they double check the balance as well as any possible run out of the rim.
BTW did anyone check the tire pressure?
Old Nov 27, 2006 | 08:01 PM
2deuce's Avatar
2deuce
I had to have a tire replaced under warranty while on a road trip and had the same thing happen....right around 40 mph. It had lessened quite a bit by the time I got back home and there's no weird tread wear. 1000 miles later, it still has a little shake. It might be a little out of round or some other manufacture glitch. The first one had a bubble in the sidewall at 2400 miles. It was hard underneath and they said the sidewall might be seperating. They said it probably wouldn't have blown, just start breaking up. I switch to Avons after the original Dunlaps wear out.
Old Nov 27, 2006 | 08:42 PM
HD7585's Avatar
HD7585
You probaly already have...........But if you haven't , Check the air psi
Old Nov 27, 2006 | 08:43 PM
jakblu's Avatar
jakblu
Is there a way you could double check them for a torgue value? I had this once (no new tire though) I was running the tire according to the manual instead of the tire recommendation. And I retorgued the steering head and it fixed it.
Old Nov 27, 2006 | 10:06 PM
FACTION95's Avatar
FACTION95
I'm no Harley mechanic, but I would have the wheel rebalanced.
Old Nov 28, 2006 | 11:26 AM
Jezcruzen's Avatar
Jezcruzen
Thanks, folks. I do check the tire pressure religiously before every day's ride - 30psi in front/40psi in back.
A friend told me to rotate the tire on the rim 90 degrees. Never heard that one before! Its time (past time, actually) for the 10K anyway. I've done most of it myself, but I will take it in an let them check and do the maintenance on the head bearings. I'll have them check the spokes and do a re-balance.
