is it me or the bars?
Old Jan 4, 2012 | 03:54 PM
deadeye's Avatar
deadeye
You just have to get used to them. You may have been used to pressing down on lower bars to turn or balance. I'd ride them for a few hundred miles before looking at anything mechanical.
Old Jan 4, 2012 | 04:43 PM
j1mmy's Avatar
j1mmy
your problem is the handle bar clamps are rubber mounted. longer bars give more leverage and they flop around a lot more. get the stiffer Polyurethane Heavy-Duty mount bushings or get some solid metal mount bushings..that should take the problem away..
Old Jan 4, 2012 | 05:49 PM
RedBen's Avatar
RedBen
I had some wide low bars on my bike before changing to some much narrower apes. I wobble a bit more if I hit a groove or something. I suspect one thing that plays into this is that you have less weight resting on the apes or at least the weight is hanging onthe apes in a different direction than lower bars. Just ride and it goes away. Probably you adjust your technique or something after a while.
Old Jan 4, 2012 | 06:16 PM
kennygsuperglide's Avatar
kennygsuperglide
It's you.
Old Jan 4, 2012 | 07:23 PM
Jeff W's Avatar
Jeff W
What helped me, tighten the steering head bearings just a dab. Then realize the wind is now catching your arms and that's transferring into the steering, take your time, get used to the bars and soon you will never be without them.
Old Jan 4, 2012 | 07:49 PM
Miked053's Avatar
Miked053
Do you feel the bars more on you? If you u might want to upgrade to poly bushings
Old Jan 4, 2012 | 07:54 PM
Ed McLellan's Avatar
Ed McLellan
Just give it a week (if you just put them on)
Old Jan 4, 2012 | 07:56 PM
shooker's Avatar
shooker
just don't go slow
Old Jan 4, 2012 | 09:56 PM
Kowan's Avatar
Kowan
Relax and enjoy it. Heavy hand on the grips due to uncertainly will have you causing wobbles.
Old Jan 4, 2012 | 10:04 PM
pccoder's Avatar
pccoder
Wobbles seem unacceptable to me. Those who suggest stuff other than "it must be you" are helpful and should be considered.
