your problem is the handle bar clamps are rubber mounted. longer bars give more leverage and they flop around a lot more. get the stiffer Polyurethane Heavy-Duty mount bushings or get some solid metal mount bushings..that should take the problem away..
You shouldn't have any wobble. Depending on its severity, the easy fix for slight wobble is like several have said with the poly bushings. I still have the stocker rubber ones, and they don't bother me so much. If I would have gone higher with the apes, it would be too much play. If it is a severe wobble, it would most likely be due to your wheel balancing like a couple dudes said, or worst-case, your steering head. Check the fall-away like chiefe and Dr. V suggested, and you'll be good to go. I have never (and most others) had any death wobble...until you get real fast, that is.
Hummm,, Agree with above, new bars changed something, makes sense that any play in the bars will multiply with the new add height and thats why the harder bushing removes that possibility.
Really wouldn't hurt to check out all the other stuff anyway. Neck bearings should be checked and greased often anyway. Do mine twice yr.
it was a combo of a bunch of little things,neck bearing play,switched the bushings in the bars and mostly me,after riding a couple hundred miles i got used to them,not to mention my wife always moves around,drives me nuts,,
Besides changing out the stock bushings to poly bushings, the risers were also changed and a one piece plate used to hold the bars down on my bike. Something that the local dealer recommended. Bottom line is that I have not had any play/wobble in the bars.
Dude, I actually broke up with a girl because she wouldnt sit still. Why is it that they have to move around right when you are coming to a stop? Enough to drive a man to drink...just sayin
There's certain times when we want Our wife's to move and other times they need to be still..
I've found out that after 40yr of marriage I now know my wife has it backwards... Suppose to be still on the bike and move in .....
They don't call it the world's largest vibrator for nothing.... and for the newer bikes that don't vibrate as much, a throttle controlled vibrator can always be added to the passenger pillon. I've seen a few women get off in the parking lot on a bike or two--sort of funny when they start howling.
it was not in the bars,it was the entire bike coming to a stop or going really slow in stop and go traffic,,,my wife also likes to put her feet down when we come to a stop always end up kicking her when i put my feet up,,
