Looking for tips on slip-on install for Deuce/Fatboy
Old Oct 23, 2011 | 06:26 PM
streeteagle's Avatar
streeteagle
Default Looking for tips on slip-on install for Deuce/Fatboy
Getting ready to install Rush slip-ons on my Deuce. Presently have SE's which were dealer installed right after I got the bike. I do a lot of my own wrenching so the install looks fairly straight forward. Anyone have any tips they can offer me to make it easier or anything I SHOULD'NT do.
Old Oct 23, 2011 | 07:10 PM
kiwideuce's Avatar
kiwideuce
you should be fine,fairly straight forward
Old Oct 23, 2011 | 07:30 PM
streeteagle
Thanks, Deuce bro!
Old Oct 24, 2011 | 07:52 AM
iupsig97's Avatar
iupsig97
What size baffles did you get? Just recently swapped my 1.75 for 2.0 and they sound freakin awesome .
Haymarket... just outside my old stomping grounds. That area has changed a lot.
Old Oct 24, 2011 | 06:31 PM
streeteagle
I got the 1.75's. Were they not loud enough for you or you just did'nt like the sound? They Haymarket area has changed, but not for the better. Too much traffic, taxes thru the roof..
Old Oct 24, 2011 | 06:59 PM
imboden's Avatar
imboden
just don't forget to clean em before you fire it up the first time, hate to burn fingerprints in it or somethin
Old Oct 24, 2011 | 07:09 PM
Nocturnalnature's Avatar
Nocturnalnature
Post up after you get them installed please. Looks like the stockers and SE mufflers bolt up the same way the cans do on my Blackline, and for the life of me I can't figure out how to get a wrench on the bolts without removing the entire system. They are located at such an odd angle that a socket and ratchet won't fit and a box end wrench doesn't fit flushly on the heads.
Look forward to hearing how you do it.
Old Oct 24, 2011 | 10:11 PM
streeteagle
Yeah, after a preliminary looksee at the bolts/nuts I decided a small ratchet box wrench with a 15 degree offset was what I needed which I picked up at WalMart. Will keep you informed on how it goes & pics after install.
Old Oct 24, 2011 | 10:26 PM
av8or's Avatar
av8or
WD-40!!!! Makes it a lot easier to remove the old muffs and install the new.
Old Oct 25, 2011 | 08:22 AM
streeteagle
Thanks for tips on fingerprints & WD-40. Would not have known otherwise.
