Samson Cholo's, torque cones?
Old Oct 31, 2011 | 11:16 AM
pnw_hd_rider's Avatar
pnw_hd_rider
Originally Posted by Samson_tech
The Samson Torque Cones will give you an advantage with an increase of 3-5 foot pounds more torque.
Thank you,
JR
Total BS.
People pushing 'torque cones' are nothing more than snake oil salesmen.
If the fuel delivery is set properly for the intake/exhaust, the cones will do absolutely nothing beneficial.
Old Oct 31, 2011 | 11:27 AM
Lawleywood's Avatar
Lawleywood
Originally Posted by pnw_hd_rider
Total BS.
Maybe you should read this article that TheTroupe posted before you start calling people names and such. JR happens to be very knowledgeable about the Samson products. Go ahead and read it, then you can apologize to him.
It can be found halfway down the page on this link.
https://www.hdforums.com/forum/softa...-question.html
Samson_tech's Avatar
Samson_tech
Former Sponsor
Even if you have not felt a loss of power you will still get more torque with the torque cones. It may not be seat of the pants increase but it will be an increase. It's a cheap way to add more power, off the line power and passing power.
Thank you,
JR
Old Oct 31, 2011 | 12:24 PM
pnw_hd_rider
Maybe you should read the article again.
Here's a quote from the article:
"Much controversy (and apparent confusion) surrounds the issue of exhaust "back-pressure". Many performance-minded people who are otherwise knowledgeable still cling tenaciously to the old school concept.... "You need more back-pressure for better performance."
For virtually all high performance purposes, backpressure in an exhaust system increases engine-pumping losses and decreases available engine power. It is true that some engines are mechanically tuned to "X" amount of backpressure and can show a loss of low-end torque when that backpressure is reduced. It is also true that the same engine that lost low-end torque with reduced back-pressure can be mechanically re-tuned to show an increase of low-end torque with the same reduction of back-pressure. More importantly, maximum mid-to-high RPM power will be achieved with the lowest possible backpressure. Period!"
Take particular notice of the underlined part.
Like I said; SNAKE OIL. Any mechanical engineer worth his salt will tell you that 'torque cones' are a gimmick. As P.T. Barnum said, there's a sucker born every minute.
Old Oct 31, 2011 | 12:32 PM
Samson_tech
Former Sponsor
To Lawleywood,
Thank you for pointing out a great article. The torque cones also give an anti-reversionary effect as well as increasing velocity in the exhaust pipe. This is why it has been proven torque cones really do work. Kenny Price, the owner at Samson, Invented this devise many years ago knowing the larger diameter exhaust at the time suffered from low velocity. The Samson torque cones were invented using old time rocket science where the gasses are constricted evenly and expelled evenly but a much better rate of speed which is the velocity of the exhaust. The smooth bore of the torque cones do not interrupt flow so are a very real functioning performance part. The dyno testing throughout the years have proven that torque cones work very well. The engines that do not need the torque cones would be a hemi head engine like the shovelhead engines. All others with the squish method of compression benefit well with torque cones.
Thank you,
JR
Old Oct 31, 2011 | 12:50 PM
Lawleywood's Avatar
Lawleywood
You should read your UNDERLINED sentence again, "it can be mechanically tuned." How do you suppose you are going to mechanically tune it?? Oh yeah, a baffle or a torque cone. Read the whole article before you mouth off again. And don't knock people that actually know what they are talking about because you obviously don't!!
Old Oct 31, 2011 | 12:56 PM
thelawnmowerman's Avatar
thelawnmowerman
Do the torque cones alter the sound?
Old Oct 31, 2011 | 01:03 PM
pnw_hd_rider
To Lawleywood,
How about some documentation to support this 'proof' you speak of? You provided a link to an article that was supposed to support your position, but you are totally ignoring the quote from that article that I posted.
Adding cones effectively reduces the size of the exhaust openings. That effectively increases back pressure. Increasing back pressure is counterproductive for producing torque/power, PERIOD.
Thank you,
JR
You obviously don't even know what a hemispherical head is. Here's a hint: the evos and twin cams STILL use hemispherical heads. Hemi heads have NOTHING to do with "method of compression". Hemispherical design is all about the angle and position of the valves to promote better air flow efficiency through the cylinder. A cylinder head that is not a hemi is called a wedge head (both valves on the same side of the cylinder).
You need to learn before you try to teach.
Old Oct 31, 2011 | 01:14 PM
Samson_tech
Former Sponsor
The torque cones will not affect the sound at all since they are up at the head.
Thank you,
JR
Old Oct 31, 2011 | 01:33 PM
pnw_hd_rider
"can be mechanically re-tuned to show an increase of low-end torque with the same reduction of back-pressure"
Same reduction of back pressure. Adding cones INCREASES back pressure, so that would NOT be "with the same reduction of back pressure".
Re-jetting the carb / re-mapping the EFI, changing cam(s) and or timing are ALL forms of mechanical tuning.
You are mixing 4 stroke dynamics with 2 stroke dynamics. As far as exhaust gas reversion as it applies to 4 stroke engines, the important factor is that the exhaust pipes are equal length. Other than that, the less back pressure the better.
Exhaust scavenging and energy waves are important issues when designing expansion chambers for 2 stroke engines. Not so much when designing headers for 4 stroke engines. If it was at all beneficial to pinch off the exhaust flow right where the pipe connects to the head, then headers/drag pipes would be designed that way.
