Vibration
Old Nov 6, 2011 | 09:00 AM
St Glide's Avatar
St Glide
Default Vibration
What year did the softails stop vibrating so bad? I had a 99 Fatboy and it was great. I went to look at a 92 Fatboy and rode it. To my surprise it felt and rode like it was 30 year older technology. I thought because it had an Evo motor it would be the same. It vibrated like a *****! What year did they finally take care of that? I know my 99 Fatboy with the factory Evo was smooth. If anyone has the answer to this I would appriciate it.
Old Nov 6, 2011 | 10:50 AM
dcgray2's Avatar
dcgray2
AFAIK, there should be no difference between the '92 and '99 softail. Both hard mounted EVO motors.
From what I know (I'm still learning) it could be a problem with a loose motor mount bolt, broken motor mount, or bad compensator spring.
Old Nov 6, 2011 | 11:28 AM
St Glide's Avatar
St Glide
I thought the same thing. However my 99 was way smoother. My buddy Chad also has a 99 Heratige and his bike was also smooth. My neighbor Marshal has a 91 it also vibrated real bad like the 92 I rode. He also told me he believed it was 98 or 97 when they made the change. But he is not sure. I would like to know for sure though.
Old Nov 6, 2011 | 11:54 AM
the blob's Avatar
the blob
i think they changed the gearing, my freinds 97 e.glide cruises at a much lower rpm than my 90 softail.
Old Nov 6, 2011 | 12:24 PM
St Glide's Avatar
St Glide
Well I believe prior to 97 the motor must be mounted different or some difference in the motor. The motor is more of a thumper the bike vibrates much more at low rpm
Old Nov 6, 2011 | 12:28 PM
the blob's Avatar
the blob
mmmmm. i wonder if its the switch from duel fire to single fire ignition?
Old Nov 6, 2011 | 06:08 PM
St Glide's Avatar
St Glide
What year did they do that?
Old Nov 6, 2011 | 11:45 PM
the blob's Avatar
the blob
i want to say 97 but im not sure.
Old Nov 7, 2011 | 12:24 PM
OldAggie's Avatar
OldAggie
5th Gear
I'm not sure about the Fatboy, but my 1998 Heritage came stock with dual fire ignition. Vibration was one of the complaints if I recall correctly.
Old Nov 8, 2011 | 08:06 PM
the blob's Avatar
the blob
did switching toa singlefire reduce the vibes? on mine its not a big deal but if i can reduce the vibs it would be better.
