07 softail standard rear end noise
Old Nov 30, 2006 | 08:38 PM
toby34's Avatar
toby34
Default 07 softail standard rear end noise
I have had this bike from new and there has been a rumbling or rubbing noise coming from the rear of the bike that you can hear when you get to 29 or 30 mph. Has anyoune had this problem or heard of this. The wheel bearing has been changed , the belt has been camford, the rim has been changed and the tire as well. What gives
Old Nov 30, 2006 | 10:33 PM
jhugs92's Avatar
jhugs92
Default RE: 07 softail standard rear end noise
sounds like you need a new exhaust, then you won't be able to hear it. i suggest rush slip-ons with 2 or 2.25" baffles!
Old Nov 30, 2006 | 10:34 PM
Doug's Avatar
Doug
Old Nov 30, 2006 | 10:52 PM
toby34's Avatar
toby34
Well you are correct about the pipes, that is on the drawing board but the pipes won't hit the street until mid feb. Will also be installing the new SE air cleaner for 07 and the sert too. I will bring that up with the tech at the dealer
Old Dec 1, 2006 | 12:08 AM
HD7585's Avatar
HD7585
You said the rim was changed.........When i changed my rim i had to use a larger spacer........Just something to check.....Good Luck
Old Dec 1, 2006 | 12:27 AM
toby34's Avatar
toby34
Well what the dealer did was put a wheel and tire setup from a softail that they had at the dealer to see if it would make a differance. no good same noise. It was a stock wheel swap for trouble shooting
TickTock
Sep 14, 2014 08:35 PM
FFLETCHER
May 26, 2008 11:33 PM
beauty
Oct 15, 2007 10:54 AM
toby34
Feb 2, 2007 04:02 PM
toby34
Welcome Area Only
18
Dec 17, 2006 10:14 PM
