put the 30t on my night train
Old Nov 26, 2011 | 08:56 PM
Mi3ninos's Avatar
Mi3ninos
Default put the 30t on my night train
I'm certain this has been well documented by many many others.
installed the andrews 30t sprocket on my '07 last week. (66t @ wheel)
borrowed the george's garage 2.25" deep socket with pilot fr a brother.
serious torque on the main nut as well known.
we beat on that nut 30 seconds at a time and it took 6 cycles for the compressor to reset to 175psi.
how or why anyone would attempt that 2.25" nut removal without the right tool(s) is beyond me.
i also dropped one belt tooth and put on a 132 falcon bdl. my stock was ripping teeth. the axle adjustment is basically in the same stock location. so doubt it would have taken a stock 133t belt.
$135 on the 30t socket, $108 belt, $48 on inner/outter gaskets, $11 HD sealing bolts, $6 on a 30MM socket (for clutch hub). I had primary oil, made a locking bar for compensator to clutch.
seat of the pants is nice on the low end. hit it hard and hang on. top end passing power is a plus. at 80mph my digital mini-tach shows 2.9. very sure the speedo is off now. will check vs another bike or smartphone gps someday. not really worried about it. i have a notable new buzz (vibration) at 75mph, not unpleasant but notable.
good upgrade for the cost. total time on the project once I began 3.25 hrs.
will be doing this upgrade to a couple of other club bikes.
Old Nov 27, 2011 | 12:32 AM
olongapo1's Avatar
olongapo1
Really interested in this modification. If you do another bike could you do a picture layout with explanations.
Old Dec 26, 2011 | 10:45 AM
JetD's Avatar
JetD
Default Great Documentation
Here is an excellent pictorial; and there are others on this Forum as well.
https://www.hdforums.com/forum/dyna-...y-install.html
Good Luck. You will like the results. I do.
Old Dec 26, 2011 | 12:57 PM
bill in okc's Avatar
bill in okc
I've got a feeling this will be my next mod. Thanks for the info & link.
Old Dec 26, 2011 | 02:31 PM
kiwideuce's Avatar
kiwideuce
interesting!! thanks
Blk/Wht/andChrome
EVO
34
Oct 30, 2018 06:03 PM
doug62
Mar 4, 2015 05:45 PM
tujo33
EVO
Jul 12, 2010 11:17 PM
janiharley
Oct 24, 2009 02:59 PM
drhooligan
Apr 14, 2009 10:39 AM
