Extending handlebar wiring
If you follow the directions on the page it should turn out to be a completely trouble free job.
http://fordfuelinjection.com/?p=7
If you can't find any of the adhesive lined shrink tubing locally all is not lost. Just swipe a bottle of clear nail polish off the wife or GF and thoroughly paint the joint with it. Make sure you pay particular attention to the insulation ends as the polish once dried will seal the ends up preventing water from migrating up the wire.
Any water that gets inside the insulation will allow the wire to corrode and sooner or later youâll start having weird electrical problems that can be very difficult to isolate later.
Soldered my own once. Got done in less time but my labor rate is higher than HD.
Bought extender kits the last time. While somewhat pricey for a few wires and connectors, it was less than the parts and labor expense for a mech or DIY solder job.
I don't know if your experienced with wiring jobs but just in case here's a web page that will show you in detail exactly how to cut/solder the wires the right way the first time.
Soldering I can do, but the wrap idea looks super easy and the tip about the adhesive tubing / clear nail polish / sealant glue to prevent corrosion is very cool. Thanks
Wow.. I learn something cool in here every day.
It works especially well when you have to splice a wire into the middle of an existing line. The tubing doesnât always shrink quite enough on one side or the adhesive canât properly seal up the gap between the two wires on the other side.
Its been my experience that if you leave any gap at all, itâs a sure bet that water WILL get in.
Using the nail polish guarantees that even if it isn't sealed completely by the tubing or the adhesive in it, its still has some protection from water and road salts.
The best part is that even if you don't have any polish laying around its only a buck or two in any grocery store for a cheap bottle that will work fine and last for years.
Before you try shrinking the tubing, especially with a Bic or other lighter, be sure to let the polish dry completely, use a hair drier if your in a hurry. Besides being very flammable the acetone or something else in the polish doesn't let some brands of shrink tubing work right when its still wet.
Have fun
As an electrician, I've used this method in various applications, the only way you're getting back to that joint afterwards is to cut the joint out completely.
