Need help...front brake bleeding and new bleeder valve nut.
Old Dec 6, 2011 | 12:12 PM
Slickster63's Avatar
Slickster63
I bought a $5 kit from Harbor Frieght ... container, tube, connectors ... container has a magnet on the side ... keeps it in place and clean.
good $5 buy
Old Dec 6, 2011 | 12:15 PM
Ash16's Avatar
Ash16
Speed Bleeders
http://www.speedbleeder.com/
Old Dec 6, 2011 | 01:15 PM
Old Skool Chopper's Avatar
Old Skool Chopper
Thanks fellas. Can anyone recommend a pump that they know works well?
Old Dec 6, 2011 | 04:35 PM
WFA's Avatar
WFA
Did anyone say speed bleeders...speed bleeders are so easy that a cave man can do it!!! Really!!!
WOODY
Old Dec 6, 2011 | 06:59 PM
Ash16's Avatar
Ash16
Mityvac if you're not going with Speed Bleeders. I have both.
Old Dec 7, 2011 | 06:40 AM
Nickrc3's Avatar
Nickrc3
Mity-Vac, from Harbor Freight. Use their discount coupons for addtional savings.
Best tool for brake bleeding.
<LI class="item first"> Mityvac Vacuum Pump
Item #39522
4.7
(9)
Read 9 Reviews
Write a Review
Only:$39.99
Old Dec 9, 2011 | 02:14 PM
Old Skool Chopper
Originally Posted by jimmers1817
I had a helluva time bleeding the front breaks on both of my softails when I switched out the cables. Tried the gravity method which I found online somewhere and the vacuum method. Still couldn't get all the air of the line. Low break lever and spongy.
I finally resorted to a trick recommended by someone here. Here's how I remember it: Remove master cylinder cap, pull break lever back and secure in that position. Turn handlebars so the master cylinder side is higher than the other. Leave like that overnight. In the morning let break lever out and give it a single short squeeze to burp the line. You may see a bubble rise to the surface. I had to do this for about 3 nights to get all the air out. Even then the lever still didn't feel just right. After I rode it a few times I noticed it had hardened up real good.
I have no idea why I had such a hard time getting the air out. Hopefully, you'll have better luck.
Hey Bro. Everyone had some great ideas, but I wanted to go the cheap route first and see if your method worked. I did it last night and the improvement in the brake is dramatic. I get it half way down now and can't go any further. I am going to do it again tonight. I just strap it with an elastic tie strap and leave the cover off. Then I burped it. amazing.
GibsonSG05
Jun 13, 2021 02:14 PM
chad.kirk1
Jun 26, 2017 04:42 AM
nkauf21
Feb 2, 2016 11:25 AM
JDavis187
Jul 16, 2014 01:32 PM
Snuggyph1
Jul 11, 2014 11:16 AM
