He fellas,
I was bleeding my front brakes and doing it the old fashioned way...open valve, squeeze brake, close valve, release brake, repeat.
After about the 1 millionth time, the wrench slipped and i rounded off the bleeder valve screw. So, 2 questions:
1. does anyone know where to get a new bleeder valve screw and
2. does anyone know an easier way to bleed the front brake. Good thing I have all winter to do it right...lol.
Since you're already in there, I would go to the dealer and get the chrome bleeder screws. Or any auto store should have them.
And do yourself the biggest favor you could imagine. Buy a vacuum bleeder. Attach it to the bleeder valve, loosen it, and start pumping the vacuum. When the fluid comes through, keep pumping till there are no more air bubbles, then tighten the bleeder valve. Easy as pie. Otherwise you'll be bleeding your brakes for days.
You can get them at Pep Boys or the like. About 30 bucks.
+1 on the bleeder. On mine, I learned the hard way when doing it manually (no bleeder) pump the handle slowly to build up pressure. If you pump it hard and fast, it will never build up pressure. Just my .02 worth
I had a helluva time bleeding the front breaks on both of my softails when I switched out the cables. Tried the gravity method which I found online somewhere and the vacuum method. Still couldn't get all the air of the line. Low break lever and spongy.
I finally resorted to a trick recommended by someone here. Here's how I remember it: Remove master cylinder cap, pull break lever back and secure in that position. Turn handlebars so the master cylinder side is higher than the other. Leave like that overnight. In the morning let break lever out and give it a single short squeeze to burp the line. You may see a bubble rise to the surface. I had to do this for about 3 nights to get all the air out. Even then the lever still didn't feel just right. After I rode it a few times I noticed it had hardened up real good.
I have no idea why I had such a hard time getting the air out. Hopefully, you'll have better luck.
Get one of them sucker bulbs that ya suck out a baby's nose with from the pharmacy and a piece of tubing that fits tight over the bleeder. Fill the bulb with fluid put the tubing over the bleeder and onto the bulb with the cover off up top open the bleeder and squeeze the bulb slowly pushing the fluid (and air) up to the top. Works fer me. Cost,, about 5 bucks... Good luck wid it.
Get one of them sucker bulbs that ya suck out a baby's nose with from the pharmacy and a piece of tubing that fits tight over the bleeder. Fill the bulb with fluid put the tubing over the bleeder and onto the bulb with the cover off up top open the bleeder and holding it up above the bleeder pointing downward squeeze the bulb slowly pushing the fluid (and air) up to the top. Works fer me. Cost,, about 5 bucks... Good luck wid it.
This is the method I use, except I use a large plastic syringe instead of a squeeze ball. Fast and easy. I take the bleeder out first and wrap it with teflon tape so it can be open without leaking around the threads (have to remove the teflon tape when finished).
The two easiest ways to do it are
A) Get a set of Speed Bleeder valves. The work like a check valve. Partially loosen the
valve. And pump the brake. Retighten the valve, top off the resevoir and you're done.
Make sure you hae a tube attahed to the vave and container to catch the fluid.
B. Go the auto part store and get a vacuum pump kit. Attach the hose and catch
resevoir to the valve. Pump the vacuum tool, eay though mine will drrain the resevoir in
6-10 pumps. Same deal tighten the valve and top off the resevoir and your done.
