1994 Custom not turning over
Old Dec 19, 2011 | 10:39 PM
jmsoftail94's Avatar
jmsoftail94
Default 1994 Custom not turning over
So I just recently had a baby which means my riding time has been drastically cut. I try to periodically get my 1994 Softail Custom out so it doesn't just sit, but its been about 2 months since I last fired it up. The other day I tried to start it and it wouldn't turn over. When I push the ignition button, I hear a click but nothing else. I bought a battery tender and it only took about an hour to charge up my battery and still nothing. I bought the bike about 5 years ago and haven't replaced the battery, so who knows how old it is. Gonna replace it and hope it starts. Any ideas what else it could be and what I should be checking? Thanks in advance, it would be nice to get it running again, before it gets put on the back burner and sits even longer.
Jake
Old Dec 19, 2011 | 10:43 PM
blackbear's Avatar
blackbear
I would start with a new battery from what you described it sounds like a bad battery.5 years is about the life span of a battery anyway.
Old Dec 19, 2011 | 11:16 PM
jmsoftail94
Yeah, I figured thats the first place to start. Hopefully its that cheap and easy.
Old Dec 20, 2011 | 12:39 AM
PanHeadRich's Avatar
PanHeadRich
If you actually bought a battery "tender" rather than a "charger", the tender couldn't possibly give you a full charge in an hour. Because your lights come on doesn't mean you have enough charge to turn the motor over.
Put a real charge on that pup then see if it turns over. If you don't have an actual charger, then leave the tender on for a few days. Like blackbear says, it is probably just the battery.
Good luck with that.
bigjosh42
Feb 3, 2019 07:40 PM
slvrscoobie
Mar 20, 2017 05:12 PM
Oscarthegreat
Jan 4, 2015 01:37 PM
bobberboi
Mar 28, 2012 06:23 PM
strtarrow
Jan 9, 2010 04:25 PM
