OEM or Lowering Kit??
Old Dec 24, 2011 | 10:30 AM
BrianG's Avatar
BrianG
heybaylor, what did you do to the rear end?
How did you determine your target position for the rear suspension?
Old Dec 24, 2011 | 10:38 AM
heybaylor's Avatar
heybaylor
took off the extentions that were on the stock shocks.
then ,(your gonna laugh) raised the preload on the shocks untill I could get my motorcycle jack under it ...
I used to have to use boards under the tires to use the jack.
the kidney busting "jolt" crossing a local bridge is gone..life is good
Old Dec 24, 2011 | 10:42 AM
BrianG's Avatar
BrianG
What rear tire are you running?
Norcaldog also added 2"-over fork tubes to gain some clearance.
Old Dec 24, 2011 | 10:48 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Its an adapter screwed on from a lowering kit. My Softail has the SE shocks on it and I have a set of regular standard ones. The standard ones are around 1" shorter then the SE. Both have the front thread part for the bushing as a single unit back into shock. Adapting would worry me but it must work for many. Opposite from what most realize extending the shock drives the suspension / tire up into wheel well lowering bike.
Old Dec 24, 2011 | 10:50 AM
heybaylor's Avatar
heybaylor
stock Dunlop,s front and rear
Old Jan 7, 2012 | 06:50 PM
BrianG's Avatar
BrianG
Can somebody with a Heritage with OEM rear suspension jack their bike up so that there is no weight on the back wheel and give me this "X" measurement?
SnoRider
Touring Parts
Dec 24, 2015 06:50 PM
shadowchrome
EVO
16
Mar 13, 2014 12:01 PM
BrianG
Dec 22, 2011 09:10 AM
BETTY-BOB
Dyna Parts
Jul 28, 2010 04:59 PM
Frisian HD
Mar 23, 2010 09:27 AM
