When you relocate the signal lights I would take apart the signal housing and pull the wires out of that then cut and extend them. I used some black heat shrink and a mesh wire loom to cover the wires that run out of the bar to the signal on the fork. The stock rubber gromet can go back in the signal housing too.
I'm not following you here.
My TS wires are bundled inside the same plastic sheath as the rest of the handlebar wiring. Are you saying that after disassembling the housing and making the cut they will pull out of the factory bundle or were yours not bundled together with the rest of the wires?
Thanks man!
I cut the bundle and moved the wires so they had space to run into the bars, cut the wires closer to the light so theres no solder joint near the switch housing because its a lot harder to run the wires cause the solder joints wont flex like the rest of the wire. Just cut the bundle extend the wires then tape everything up so the wires are protected and run in the right direction so they dont get pinched when going into the bar.
