Broken drive belt...again
Old Jan 12, 2012 | 05:36 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by DR. V-TWIN
A close friend of mine has a 160 on the rear of his 05 and has for at least 20K miles without issue. Granted that when the wheel was put on the shop ensured a correct offset with the hub on their wheel. So I guess it could be the offset on the hub that is causing it.
Drew
An 05 has 1/4" primary offset "out of the box" compared to a 98...or 1/4" more room for a 160...lot of difference
Old Jan 12, 2012 | 06:05 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Gotcha. Thanks Tom. I was unaware of that obviously.
Drew
Old Jan 12, 2012 | 06:19 PM
story808's Avatar
story808
Yup a 05 comes with a 150 already so you can just slap a 160 on... Now I only know about twinkies and not much about EVO's But I thought the trans and motor is 2 pieces unlike the twincam's that are bolted together.
If that's true... would the trans have somehow become misaligned causing all these belts to bust?
Old Jan 12, 2012 | 06:59 PM
Tom84FXST's Avatar
Tom84FXST
A misaligned trans would cause at least an oil leak or probably a broken inner primary. Most likely cause is the rear sprocket was spaced out so the belt would miss the tire. If you move the rear sprocket, you have to move the trans sprocket an equal amount to keep things lined up. 1/4" trans/primary offset is probably the easiest fix to keep the new wheel/tire combo...Vulcan sells a kit: http://vulcanworks.net/store_4/produ...&cat=90&page=1
Old Jan 12, 2012 | 09:18 PM
story808's Avatar
story808
Gotcha... I would just swap to chain if I went trough 3 belts... since he gotta go in there anyway.
Old Jan 13, 2012 | 08:46 AM
balleta's Avatar
balleta
6th Gear
I remember when this was done that no other part or spacer was needed according to HD instructions in Kit # 43684-99A. Just the new 1 1/8 belt, pulley and miscellaneous gaskets.
Anyway, it seems everyone agrees on misalignment. I will check again on that before disassembly.
I'm still thinking about the chain swap and maybe a wider(240) tire while at this episode. Or if I go the chain route I can go the wider tire in the future also. Deci$$ion$$...Deci$$ion$$...
Old Jan 13, 2012 | 05:14 PM
Tom84FXST's Avatar
Tom84FXST
Sucks you bought that high dollar HD kit,and your bike is breaking belts. I have a 250 kit lying in my living room..probably start installing it next weekend. I will post pics of how I line everything up.
Old Jan 13, 2012 | 09:29 PM
Bluehighways's Avatar
Bluehighways
How about four pictures of the broken belt.
Up close so we can see the break. One of the top, one of the bottom and one of each side of the belt.
Old Jan 30, 2013 | 08:44 AM
old coot's Avatar
old coot
1st Gear
Default broken belts
Hey Balletta, my son had a breakage problem also after he installed custom rims.did everything others told you to do and it still happened. set up dial indicator on rear pully, guess what, it had .025" runout in the assembly. pulled everything apart found half of it in the hub the other half in the pulley mounting surface.trued both surfaces and the problem stopped. hope this helps cause them suckers aint cheap.
Old Jan 30, 2013 | 10:22 AM
IronAss's Avatar
IronAss
I know this thread is a year old but does anyone know if the OP figured our what the cause was?
