Advice on 103" Build!!!!!!
Old Jan 15, 2012 | 07:56 PM
NorCalFBLO's Avatar
NorCalFBLO
With my 2010 Fatboy Lo, I went with the 103 bore, 10.5:1 compression, SE259 E cams, manual compression releases, and no head work other than new valve springs. I already had a D&D Fatcat, SE A/C, and PCV. My dyno guy also really likes the TTS.
My dyno numbers are 111.18hp and 116.94tq.
After the build my clutch was slipping in higher RPM's in 4, 5, & 6 so I added an AIM variable Pressure Plate VP92T and it solved the slipping problem. I did not want to go with the stiffer spring as I did not want a harder clutch level pull. With the AIM the clutch pull is easier than stock.
I do not feel the 259E cams come on later as mentioned above. Mine seems to come on just after 2000 RPM and pull hard to redline, 6200 RPM's
Here is a copy of my dyno sheet.
Good luck with your build.
Old Jan 15, 2012 | 08:43 PM
HDCrossbones09's Avatar
HDCrossbones09
NORCAl Congrats on the hp and tq numbers!!!! Nice build!!
Old Jan 16, 2012 | 07:13 AM
Fatboylorider's Avatar
Fatboylorider
NorCalFBLO, that is a very nice Dyno sheet!!!!. Very close to what I hope to achieve!!! Looks to me that the HD 103" stage 4 kit might be the way to go!!!.....I have a Harley Mechanic that seems to be very confident with this kit, but he prefers the TTS Master Tuner to the Sert. I wonder if I can order the stage 4 kit with out the SE Tuner?????
Old Jan 17, 2012 | 08:21 PM
boosteddelslow's Avatar
boosteddelslow
Those are some nice numbers. Good job.
jeffbetrollin
Engine Mechanical Topics
Feb 13, 2016 01:54 PM
Varooom
Nov 24, 2015 06:06 AM
gatorwalt
Exhaust System Topics
39
Jan 29, 2008 10:10 PM
Pickglwd
Nov 21, 2007 04:26 AM
Ultra07
Jan 6, 2007 01:56 AM
