Help no brake lite
Old Jan 21, 2012 | 05:31 PM
zworld's Avatar
zworld
Default Help no brake lite
Just got done replacing my switch housings, I had broke a blinker wire on the rite side turn signal, I got that spliced back together so thats ok. I need to bleed front brake because I guess i had it upside down too long during install. Well heres my problem, i have no rear tail or brake lite. Any suggestions? Thanks
Old Jan 21, 2012 | 07:21 PM
FroggyFatBoy's Avatar
FroggyFatBoy
check all your fuses.
Old Jan 21, 2012 | 08:48 PM
oct1949's Avatar
oct1949
Does Ur rear pedal seem OK,?? or just Ur front.?
Old Jan 21, 2012 | 09:13 PM
zworld's Avatar
zworld
Rear brake is fine. Just not sure why I don't have a brake lite. Is there a fuse for just the brake lite? I have the manual, it shows the fuses, just says lites on one of them. And all my lites work, just no tail or brake lite.
Old Jan 21, 2012 | 09:42 PM
oct1949's Avatar
oct1949
If U redone the front lever in anyway. there is little button in the right housing side of Ur housing that can be messed up. Happens a lot on those who change bars..
That little button is what makes Ur brake light work.. MAYBe U broke that switch..
Old Jan 22, 2012 | 01:17 PM
zworld's Avatar
zworld
Thats what I'm wondering, but after breaking the wire on the turn signal I was very careful putting it back together. Wouldn't I still have my tailite?
Old Jan 22, 2012 | 01:24 PM
RidemyEVO's Avatar
RidemyEVO
If its not completely bled the brake lite will not work, I know this applies for the rear anyway.
Old Jan 22, 2012 | 01:28 PM
zworld's Avatar
zworld
Im still trying to bleed them.
SGMongoose
2014-2024 Touring Models
15
Nov 27, 2015 06:55 AM
McMurphy
EVO
15
Aug 19, 2013 05:37 PM
TexFF
Jul 24, 2013 07:35 PM
Joboo1966
Aug 28, 2010 11:24 PM
Morgaja7
Oct 25, 2006 11:12 AM
