Fuel tanks differences EFI/carb
Old Jan 29, 2012 | 03:49 PM
thelawnmowerman's Avatar
thelawnmowerman
Default Fuel tanks differences EFI/carb
Hey guys can anyone help me out and tell me physical differences thatI will be able to see, between a carb and an EFI fuel tank.
I have a 2005 fatboy fuel tank that I need to identify whether it is EFI or not.
Old Jan 29, 2012 | 04:52 PM
hspring03's Avatar
hspring03
In 04 and later both the carb and EFi tank are the same. Previous to that, 01-03 EFI tanks had the big hole o\in the middle between the caps for the fuel pump assembly. A carb tank 00-03 did not have the hole.
Old Jan 29, 2012 | 05:01 PM
thelawnmowerman
So If I've got an 05 tank with an oblong hole in the top then its either fuel injected or will fit a fuel injected bike?
Old Jan 29, 2012 | 05:05 PM
IronAss's Avatar
IronAss
I have an 05 as well. If you look in a parts book for 2005 you will see that the part # is the same for Carb or EFI. The only difference is you need an adapter for the petcock on a carb'd bike.
Old Jan 29, 2012 | 05:06 PM
hspring03's Avatar
hspring03
This is a fuel injected tank. Hole in the middle. The carbed tanks prior to 04 didn't have it
Old Jan 29, 2012 | 05:15 PM
thelawnmowerman
Thanks Guys
The tank I have is an 05 Fatboy, like I said it has the hole in the top, it also has 2 outlets down below for the petcock but one is blanked off. It sounds like I may have what I need.
Old Jan 29, 2012 | 05:20 PM
IronAss's Avatar
IronAss
Here's a link to an online parts catalog. It should give you all the info you need regarding a tank.
http://partsfinder.onlinemicrofiche....artsfinder.htm
96 Ultra
EVO
16
Oct 30, 2017 05:19 PM
wildfonz
Carburetor Related
May 15, 2015 12:15 PM
mcfaddenfxdx
Nov 26, 2008 07:46 PM
bv
Exhaust System Topics
11
Mar 3, 2008 12:59 AM
KenM
Apr 20, 2006 07:39 PM
