NGK Iridium spark plugs
Here is a link for the poster that wanted to know the p/n http://www.dragspecialties.com/produ...umber=DCPR7EIX
Not really a big issue, just a personal preference. My bike is a carbie so I most likely wouldn't encounter any of the ecm problems that FI bikes might. Not too expensive of a bling anyway.
Absence of audible detonation doesn't necessarily mean that the system is working correctly with a different plug. It may never have seen conditions where detonation control was needed, or exhaust may be too loud to hear it, or it could also be pulling timing when it doesn't need to.
Note: Iridium NKG's are available with the correct resistance value to maintain the knock sensing system in the HD's.
There is only one reason that most cars makers use the more expensive iridium plugs. Gas mileage. It is because most cars are feed E10 and the iridium fires it better which yields better burns thus increase mpg's. Car makers are forced to use every strategy to achieve the ever increasing fleet average mpg goals. Some even resort cheating ie VW.
How do we confirm this?
I believe that 6 ohms is the HD plug and any manufacturer has them. Most plugs today are resistor.
I use those in 19 HD's currently and five more that I have traded. No pinging even on the 110 with flowed heads and Stage I.
If you are too lazy to check the charts just buy them from J&P. They have already done the work for you.
Fear and ignorance makes some folks prisoners of their own minds.
Ad hominems are uncalled for - play the ball.
Do you have data for this other type of resistance?
The main advantage of iridium plugs is that the tougher metal doesn't erode as fast, giving much longer service life and lower maintenance (up to 120 thousand miles in some cases). This is especially important on vehicles where space constraints make the plugs very difficult to replace. Harley plugs are a piece of cake to replace.
The resistance level of the plug is essential to HD's ion sensing system. A non resister plug will corrupt the system as will a plug with to high resistance.
Want a cheaper plug than the HD branded one? Just get the Champion plug listed for an HD.
The main reason for iridium plugs is the concentrated spark from the tiny wire which ignites an E10 or higher content alcohol gasoline faster than copper core plugs. The secondary reasons are self cleaning and long life.
I ride 30,000 to 40,000(@37,400 this year) miles per year. Running E10 87 octane and achieving 50 mpg on the TC's from 88's to 110's saves me $700 to $800/yr. that is more than enough to buy a few sets of iridium plugs. I can not hear what anyone else is saying because I have researched the issue and have demonstrated for several years the merit of using the iridium plugs.
Warpfactor: The ion sensing system measures the TOTAL resistance. and responds by retarding the timing when it goes beyond the set standard.
Since you're not well briefed on the tech end of things, think of it this way:
If there was a challenge igniting and burning 87 octane E-10 properly, tailpipe emissions would increase. And this is not what outfits that do extensive testing, (vastly more testing than your 40K miles per year), like the EPA and engine manufacturers have found.
Personally, I don't run 87 octane in my Harleys, but premium. Why? It's what the manufacturer recommends, based on much more extensive testing than an individual owner can do, and it provides an extra margin of safety against engine-killing detonation. But if you're averaging 50 mpg, you aren't running very hard, so maybe 87 octane will be fine for you.
