Need help with Clutch cable...
Old Feb 15, 2012 | 08:22 AM
Redbeard719's Avatar
Redbeard719
Originally Posted by stng_96
wow talk about bad luck, ive never heard of anyone doing that, how much pressure did you put on the rod? I only go finger tight, then back it out.
Yeah, talk about some bad luck. It was only after the pressure plate broke that I trout about the schematics. Baking the release plate out would have given me less tension and I coulda adjusted the cable properly. I was too worried about the details in the service manual.
Oh well, I've always wanted to pull the outer primary cover off.
Old Feb 16, 2012 | 11:08 AM
justice469's Avatar
justice469
Originally Posted by D94
Make sure your cable is all the way back in the housing. Loosen the cable adjustment on the cable. Open your derby cover. Loosen the jamnut. Back the adjustment screw out enough, not all the way.Tighten your cable adjustment now. Pull your clutch lever till it is all the way back and let go. Now tighten the adjustment screw with an allen key. Watch your clutch lever move out to its normal spot. Once that happens you should feel the adjustment screw stop. Now back it out 1/2 to 1 turn and tighten jamnut. You can take up the excess slack with the cable adjustment now.
Thanks I'll try this when I get home.
Old Feb 21, 2012 | 11:55 AM
justice469's Avatar
justice469
This worked, thanks.
Old Feb 21, 2012 | 04:16 PM
D94's Avatar
D94
Glad to hear. Ride safe bro!
Grimace97
Sep 3, 2012 08:39 PM
Dew Me
May 11, 2012 10:02 PM
arbound1223
Aug 22, 2011 10:56 AM
Kaycee
May 27, 2008 03:12 PM
bensonjv
Nov 16, 2006 10:38 PM
