Another flawed LED??
Old Feb 15, 2012 | 11:45 AM
cmosentine's Avatar
cmosentine
Default Another flawed LED??
Hi all: I need some help from someone who owns a Harley LED headlight. If you look into the low-beam lens (the top one) do you see a rectangular opening with a slight dip along the bottom of the opening. Also, is the LED element (small yellow squares at back of the headlight) mostly covered up?
Thanks, Chris.
Old Feb 15, 2012 | 12:26 PM
hoethree's Avatar
hoethree
All I can see is a BRIGHT LIGHT!
Old Feb 15, 2012 | 12:37 PM
outgood's Avatar
outgood
Same here. I can't see anything through the top low (or bottom) projector lense whan not lit, and only bright light when lit. Mine is a larger one for my street glide, but I believe the same type. Are both you rectangular "D" bulbs lit also? They should be on hi or lo.
Old Feb 15, 2012 | 12:51 PM
cmosentine's Avatar
cmosentine
I have mine sitting in my office currently. Bright lights make it easy to see. Could you use a flashlight. This is what the opening (hole through the chrome reflector) looks like on mine.
--------|______|
TheMurf
May 15, 2019 06:00 PM
Tarkus60
Jan 17, 2019 06:31 PM
HD07King
Sep 15, 2016 09:47 PM
zachr4x4
Nov 4, 2015 12:38 PM
Garemlin
Oct 25, 2010 09:30 AM
