Top motor mount????
Old Mar 11, 2012 | 06:05 PM
1980FLHShovel's Avatar
1980FLHShovel
Default Top motor mount????
I need some help finding a top motor mount for my 2010 Heritage 96 twin cam w/ fuel injection! After a day of trying to get some mods done on the bike and having problem after problem I am burned out.
I wanted to replace the cowbell horn as I just don't like it covering the motor the way it does. I bought a horn relocation kit #69180-02a.
Got it mounted up nice but the old motor mount has the horn mount tab hanging down and it looks like crap! I can take it off and cut the tab off but I would rather just swap it out. I can only seem to find the Roland Sands one and it is nice but I don't need a $200 engine mount that is hidden under the fuel tank.
Can anyone recommend a nice motor mount that doesn't have the horn tab or holes for a coil mount? I don't care if it is chrome or zinc as I could always have the zinc one powder coated. I just can't seem to find one that fits my bike......
Thanks for any help!!!!!.......................
Old Mar 11, 2012 | 06:24 PM
NC D'LUXE's Avatar
NC D'LUXE
Try this one at J&P Cycles or BKriders, or any other place that sells parts. It won't be to hard to find.
Old Mar 11, 2012 | 07:10 PM
1980FLHShovel
I found that one but it has the horn tab on the front that I'm trying to eliminate. I'm looking for something like number 26040 or 26052 on this page http://motoscycle.com/store/page16.html that will fit a 2010 96" twin cam. I'm not sure if the 88" twin cam is the same bolt pattern.
I did a quick check of BKriders (thanks for that name, I never heard of them) but they all seem to have the tab on them also.
Old Nov 21, 2012 | 11:57 PM
sfrisby6022's Avatar
sfrisby6022
Looking for the same thing - any luck ?
This looks like it might work.
http://www.debrix.com/Extra-Heavy-Du...p/71007-k1.htm
Old Nov 22, 2012 | 06:15 AM
Redder's Avatar
Redder
i took the oem mount off....ground down the tab then rattle caned it black. cheap and works.
also...RSD has some nice mounts. but $$$$$$$
http://www.rolandsands.com/categories/motor-mounts
Old Nov 22, 2012 | 07:36 AM
1980FLHShovel
I just ended up removing the stock one and cutting off the horn tab and just buffing it and it came out nice. You can't really see it under the fuel tank on the Heritage anyway. Wasn't about to spend $200 on a RSD one!
Old Nov 22, 2012 | 11:07 AM
sfrisby6022
Happy Thanksgiving ! Did you have to remove or lift Gas Tank ? I haven't really looked under there yet - just looked at the parts breakout in the 2008 HD Parts Catalogue
Any challenges getting the mount removed and put back on ?
thanks
Old Nov 22, 2012 | 11:19 AM
De luxe's Avatar
De luxe
You actually cut and modified the mount!
Im proud of you.
Old Nov 22, 2012 | 11:27 AM
soft 02's Avatar
soft 02
Do it yourself if you got the tools.
TriGeezer
Jun 29, 2016 07:16 PM
wlibert
Jun 1, 2012 08:31 AM
wildog57
Feb 4, 2010 10:26 PM
jcmer22
Feb 2, 2010 05:53 PM
relli
May 12, 2007 04:09 PM
