Sorry for not being good enough at research to find the answer but I need to know if the stock crossbones bags will go on my lo. I can't find if the bolts will line up. Anybody know for sure?
Easiest and quickest way to find out that I can think of is to use the newest version of the accessories catalog.
Find the bags in there and see what models and years they fit and if there are any special brackets listed in the fine print for the model/year bike you want to put them on.
Off hand I can't see why not.
The worst case would be that you have to fabricate some kind of adapter brackets for them.
But generally most bags that will fit any one model Softail without shotgun exhaust will fit most other softies.
Most of the time they use the same mounting brackets as well.
My local dealership is over an hour away. The catalog says no but I think that is because of the stock exhaust which I don't have anymore. I think I will get them and just make then work somehow. Thanks
