Springer Classic Headlight Adjustment
Old Mar 19, 2012 | 08:44 PM
81Heritage's Avatar
81Heritage
Stage III
Default Springer Classic Headlight Adjustment
Hello all, I searched high and low here for the answer but alas I can't find it.. If I missed it I apologize. As the title says the headlight is aimed to high and needs to be lowered. How do I do it??
Thanks all
G
Old Mar 19, 2012 | 09:49 PM
SprungDave's Avatar
SprungDave
If your Springer is anything like mine, you need to loosen the bolt that holds the headlight bucket to the mount and re-aim the light and re-tighten the bolt.
Old Mar 20, 2012 | 06:32 AM
JakesDad1's Avatar
JakesDad1
I've found with mine that messing with the bolt is a waste of time. I just grab the light bucket and force it in the desired direction. Very miner movement is all thats required.
Old Mar 20, 2012 | 06:47 AM
Tampa Fatboy's Avatar
Tampa Fatboy
I measure from ground up to the center of the light, find a wall 20-25' away and mark the measurement you just took. Adjust the light to the center of that mark.
onekawboy
Aug 9, 2018 05:25 PM
ironfist_001
Mar 30, 2010 10:39 AM
JRK5892
Aug 13, 2008 04:22 PM
schumacher
Jun 3, 2008 09:21 PM
skullhead
May 28, 2008 02:01 PM
