springer rockers
Old Dec 25, 2006 | 10:52 AM
harleylightweight's Avatar
harleylightweight
Default springer rockers
when adjustingthe rocker swing25/35inch pounds on the springer rockers (late model) the service manual says to turn the rigid pivot bolt and rocker.My question is where do you put the torque wrench? With the bearing retainer covering thehead of the pivot bolt the only other placeto put the torque wrenchwould be the hex nut.Is that the place to take the rocker swing reading?(inch pounds) Or am I missing something.thanks
Old Dec 25, 2006 | 11:04 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: springer rockers
You read it correctly...
You will need adapters to get your wrench to adapt to theHex wrench....
Old Dec 25, 2006 | 11:12 AM
harleylightweight
So the torque wrench goes on the retainer lock nut toswing the rocker?
Old Dec 25, 2006 | 12:25 PM
Shovelhead Bob
Bearing retainer......
Torque to 12-15 in/lbs, then torque the retainer nut (While holding the retainer stationary).....
With the Nut torque, it will increase the retainer torque to close to spec.....
If you do it the way the book states, you will be above the drag, and rockers won't move freely....
Old Dec 26, 2006 | 09:07 PM
harleylightweight
Hi BoB, thanks for the info. I torqued the reatainer to 25 and the rockers came in at 30 inch lbs. perfect
baka1969
Jan 4, 2015 05:46 AM
xxbones
Feb 16, 2013 01:15 AM
lloydrtr
Nov 1, 2011 08:13 AM
Xuallus
Apr 14, 2009 06:22 AM
fb2005
Exhaust System Topics
Sep 7, 2006 04:01 AM
