springer problems
Old Jul 21, 2012 | 07:16 PM
xxbones's Avatar
xxbones
Stage III
Default springer problems
I have a 2009 harley crossbones. The springer does not rock up and down like I think it should. Stays in the down position when front brakes are applied. I checked the service manual and checked the rocker bearing retainer torque. the recommended torque is 25-35 in-lbs. When torqued to these specs I can hardly move the rocker. Shouldn't the rocker move easy? This my first springer. any ideas?
Thanks
Old Jul 21, 2012 | 07:21 PM
ghostrider69's Avatar
ghostrider69
Are the springs adjusted within specs?
Old Jul 21, 2012 | 07:46 PM
xxbones's Avatar
xxbones
Stage III
The springs seem to be ok. I think the problem is the amount of torque used on the rear rocker bearing retainer.
Old Jul 22, 2012 | 09:24 AM
back again's Avatar
back again
have you or service had the rockers apart lately?Or any of the front end for that matter?
All tq. values are in ft. lbs not inches.The jam nut on my 96 is 95-105 ft lbs.Kinda sounds like spherical bearings are either dry,they need to be greased,installed backwards or someone tq'ed the living **** out of them. Also a possibility a broken rebound spring or the nuts have backed off.Plenty of things could be wrong but without hands on it would be hard to diagnose on here. If your gonna wrench on your bike get a HD service manual.Springers are not involved and neither is the maintenance to keep them working properly.
Old Feb 15, 2013 | 11:41 PM
blastonerski's Avatar
blastonerski
Xxbones, did u ever find a solution for this?????
Thanks
Old Feb 16, 2013 | 01:15 AM
FLYING_BURRITO_BROTHER's Avatar
NOT A MODERATOR
This exact thing happened to mine a while back. The front brake arm was binding. It had to be cleaned and adjusted.
SJ12DS
22
Apr 12, 2026 10:32 PM
volks-man
Apr 16, 2013 06:21 PM
hedgehorn
Aug 3, 2010 09:20 PM
harleylightweight
Dec 26, 2006 09:07 PM
fb2005
Exhaust System Topics
Sep 7, 2006 04:01 AM
