fatboy with a street glide tank
Old 03-25-2012, 09:16 PM
rgabrieljune's Avatar
rgabrieljune
rgabrieljune is offline
6th Gear
Default fatboy with a street glide tank
Hello everybody have a question I have a 07 fatboy n I wanted to see if I can install a 2010 streetglide gas tank on it I like the clean look of it or is it a dumb question
Old 03-25-2012, 09:32 PM
Branner's Avatar
Branner
Branner is offline
Nice idea, 6 gallon tank too! Both fuel injection, don't see a problem. Where you gonna mount your speedo?
Old 03-25-2012, 09:41 PM
fcsallan's Avatar
fcsallan
fcsallan is offline
Can you mount it? or Can you just bolt it on? Two seriously different questions. The tank will not just fall on your frame and bolt up, as stated above, you have to consider where your speedo / console is going to go, you will need to either modify the new tank with a bolt mount and then modify the profile of the console or you would need to handlebar mount the speedo, or just do without but then there is the question of the other indicators and ignition switch. It can be done, hell with a little work, anything can be done.
Old 03-25-2012, 09:42 PM
rgabrieljune
6th Gear
I was thinking hiding it n the ignition mounting on the side by the horn
Old 03-25-2012, 10:02 PM
Rakthi's Avatar
Rakthi
Rakthi is offline
Looked both tanks up on one of those online parts list ...
The left tank is the 2007 fatboy and the right one is the 2010 street glide.
Looks like they bolt on to the frame differently!
Might work with some fabrication. Interesting project!
Old 03-25-2012, 10:32 PM
rgabrieljune
6th Gear
Thank u I'm start tomorrow taking everything apart ill post some pics soon
Old 03-26-2012, 06:55 AM
dickey's Avatar
dickey
dickey is offline
Received 5,480 Likes on 2,478 Posts
I think it would be too involved to be worth it. Too many different factors to consider. Not like the old days when you could put a Sporty tank on an FLH in an hour.
Old 03-26-2012, 06:57 AM
rlowride's Avatar
rlowride
rlowride is offline
Do a road king tank...
skewzme
11-10-2017 10:33 PM
cgtrigg
03-04-2013 02:46 PM
MOTB180
04-11-2012 04:03 PM
melbharley
01-27-2011 10:05 PM
dex0807
09-02-2007 10:26 PM
Quick Reply: fatboy with a street glide tank
