Springer front shock question
Old Mar 26, 2012 | 02:45 PM
reservoir dog's Avatar
reservoir dog
Default Springer front shock question
I removed the shock from my springer frontend to clean the springs behind the shock . While I had it off I noticed it is much harder to extend but compresses easy. I have had other springers and noticed this one does have a little more nose dive under braking . Is this normal for the shock to compress easier than extend. Thanks
Old Mar 26, 2012 | 03:02 PM
Crash75's Avatar
Crash75
That is normal for a shock. They need to compress fast with almost no resistance to absorb the bumps in the road and avoid transfering these bumps to the bike and rider. On the rebound they need resistance or dampening to prevent spring oscillation. With the shock out of the bike it seems very stiff but in the bike with the heavy springs, it works just fine.
Old Mar 26, 2012 | 03:11 PM
reservoir dog
Thanks Crash, Kinda what I thought , just wanted to make sure the shock isnt worn out . The bike is a softail standard with 40k miles , not sure what year the frontend is or miles . BTW that is a badass springer in your pic.
Old Mar 26, 2012 | 06:44 PM
Crash75's Avatar
Crash75
Thanks Dog. I just got done doing some winter mods and hope to have some pics on here in the next few days.
Old Mar 26, 2012 | 09:52 PM
Iron Butt Springer's Avatar
Iron Butt Springer
Thought I was the only one **** enough to remove that shock to clean behind... LOL well i also changed the bolts and put in polly bushings
Old Jan 15, 2013 | 06:54 PM
mikiedaman's Avatar
mikiedaman
Stage III
Default Ploy Bushings?
Tell me where and what type bushings you used on the shock plz.
I am installing a rake kit and the 4 bushings (2 halves on top and bottom) and mine are totally deteriorated.
Michael
Old Jan 15, 2013 | 06:57 PM
mikiedaman's Avatar
mikiedaman
Stage III
Default Poly Bushings?
Michael
Hanscarlo
Mar 4, 2018 07:41 AM
ShadowforNow
Dec 23, 2015 05:22 AM
twowheelsforever
EVO
Nov 16, 2008 05:03 PM
nemick
Aug 16, 2008 11:45 AM
ckamin
Jun 6, 2006 01:34 PM
